OctaneRender® for Poser (Windows/OSX) 3.03.3 [OBSOLETE]
ch0pper
copy/paste of materials between the plugin
what plugins does this support?
W7 64 bit |I7-3970X | GTX 780 X2(6GB) GTX 780TI X2 | 64 GB DDR3 RAM
Real Skin & real hair for Poser / DAZ Studio OctaneRender/iray - coming soon
Mine :-) Well, Rhino, Inventor, AutoCAD, Revit. Not implemented in the Modo or ArchiCAD plugins. Copy/Paste works between the Poser plugin and Octane Standalone (but not for "embedded" texturemaps - ie. texturemap inside ORBX files). I recall reading that the DazStudio plugin had copy/paste from the Windows clipboard - but I have not had confirmation of that. Unsure on LW/Maya/3ds/C4d. The Clipboard Copy/Paste functionality is "experimental" at this stage - but a step in the right direction.
ch0pper
step in the right direction. hell yes it :) thanks for this
Apophis
Hi Paul,
where can I enable - Added Out-of-Core Textures -? I didn't found it. I see only the out-of-core statistics.
Its a new checkbox in the Configuration window.
TRRazor
Thanks a bunch for the quick update, Paul.
As shader developers particularly the possibility to copy materials to clipboard will probably vastly improve our development speed.
Also, finally GPU texture limits are behind us :)
Apophis
no new checkbox in the configuration window. will take a look tomorow.
Masterstroke
hi, do I need an Octane 2.21 standalone in order to run this plugin? All I see is a 2.16 stand alone version.
TRRazor
It's there, check the Setup button in the Settings tab of OctaneRender.
Pls see attached image. There is a bug preventing the switching OFF of Out Of Core textures which will be rectified in a future release.
The plugin runs independently of Octane Standalone, so the Standalone version doesn't matter.....UNLESS you are exporting scenes from the Poser plugin to render in Octane Standalone, in which case you will need release 2.21 (which is in Development Build Releases forum).
Return to “Poser”
