Cinema4D version 2021.1.7 (Old stable) 16.12.2022
- jayroth2020
Did you use the EXtractoR effect in AE? That is how you get the various layers into AE so that they can be properly used. You can choose the desired layer from the EXtractoR menu in the Effect Controls tab in AE.
- jayroth2020
If you still run into trouble, file a support ticket: [email protected] — do a Files > Save Project with Assets... archive the result and send it in along with the ticket for us to review.
I have found the problem,
if you render multilayer file it works with exr(Octane) if you render single files it does not work.
Project attached
Project attached
- Attachments
- Custom_AOV_SingleFile_exrOctane.zip
- (137.72 KiB) Downloaded 197 times
It's still working herey81r wrote:I have found the problem,
Project attached
I found a small mistake that's crashing on material creations. New fixed builds are re-built and will be up ASAP. Sorry troubles
EDIT: Builds are FIXED for now
- SilentPartnersStudio
I just ran into this issue today.aoktar wrote:It's still working herey81r wrote:I have found the problem,
Project attached
Rendering separate passes with DWAA compression the UV pass will not open in AE.
It does open correctly in DJV
Changing the compression to RLE the UV pass opens correctly in AE.
Somewhere something is broken
The thing is working with any older version? I don't have AE to check but it looks like working with the other softwaresSilentPartnersStudio wrote:I just ran into this issue today.aoktar wrote:It's still working herey81r wrote:I have found the problem,
Project attached
- blackcat321
When the live viewer is enabled, c4d will crash when creating any material.
cinema4d 2023
octane 2021.1.6 r5
cinema4d 2023
octane 2021.1.6 r5
