Beta 2.2 RC1: 3Ds Max plugin testing thread
kubo
your using the wrong version of octane, in your filepath it reads 1.21, and the exporter is for 1.22 up.
1.21 doesn't have the same flags, so thats why it doesn't understand the command.
kilaD
bazuka wrote:@kilaD
my friend i have manage to fix ur script with spaces ;) let me know if u want me to send u
there r also a lot of bugs, ur leaving obj behind when u render anim, also when i use anim mode if i have 10 frames script will run 10 octans in same time...
cheers
ok ofcourse send it over, i guess you mean the pre2011 version?
Hello
bazuka
yes for previous ver of max ;)
here is it ;) let me know when u get it so i can remove it from this msg
max2octane2008.rar
(4.87 KiB) Downloaded 314 times
Maya 2009 x64 & Maya 2011 x64
Windows 7 x64 & Windows XP x64
2x Quad Core Q6600, 8gb, Nvidia Gtx 260 & Gtx 460
kilaD
Bazuka,
i cant really see what you have changed. Could you please comment the code you changed?
And for the issue with opening hundreds of octanes.. hiddendoscommand doesnt work in 2008,
if you have any ideas let me know!
k
Hello
kilaD
Updated script (1.022d) available for download in the second post in the thread!
Hello
kilaD
rman1974 wrote:Is it possible to translate camera roll to octane? If camera roll in 3dsmax is not equal to zero - octane camera isn't match.
No, i dont think it is possible now. Octane reads only camera/target positions. I agree, camera direction would be nice.
Hello
kilaD
n1k wrote:Is it possible to achieve ,via scripting, that 3ds max continues to export obj frames while previously exported frame is being rendered in octane. That way octane would just fetch next frame from folder without need of waiting for 3ds max.
n1k
No, the loop must be halted or you will end up with hundreds of octanes clogging your system :) Anyway octane needs to save and exit for each frame.
But i have implemented an option to only export the camera, suitable for flythrough animations, saves a lot of time
as it doesnt export the obj for each frame.
k
Hello
NBraz
Thanks kubo!
cecofuli
kilaD wrote:
justix wrote:Any plans to export vray lights and materials?
When arealights etc are implemented in Octane, yes
I'll look into vraymaterial conversion, shouldn't be that hard to implement
edit: ah didnt see your post Mads. I forgot pressing submit an hour ago :)
+1
We can use a free converter, but sometime the conversion not work very well.
So, if you can implement in the octane exporter, this is VERY, VERY useful.
Also the VRayLight exporter (VRayPlane and VRaySphere) when octane will be ready are also very important IMO.
So, switch to VRay in Octane is very fast and the user can work in VRay and also in Octane in the same way.
www.francescolegrenzi.com
FACEBOOK
I7 920 | 24 GB RAM | 1x 570GTX 2GB | 480 cuda cores
n1k
n1k
k
Tnx for reply:) Exporting only camera for fly through animations is wonderful feature.
n1k
[email protected], 8gb RAM, Gainward GF 460 GTX 2048mb,Win7 64bit.
http://continuum3d.blogspot.com/
Return to “Autodesk 3Ds Max”
