OctaneRender 2 for Modo [OBSOLETE]
funk
face_off wrote:In particular, if you are using the Color Management suggestions at http://render.otoy.com/manuals/Modo/?page_id=959, these will definitely need adjustment.
Not sure why they are changing this stuff now. Anyway, simply change ISO from 55 to 22 and it will match modo's output once again.
Thanks Funk. Manual updated.
riggles
Didn't they change it back? Or has that not hit the plugin yet?
Gamma change was rolled back - exposure change is retained.
Talleman
Paul,
I just got the power SubD nurbs plugin for modo, and for some reason it crashes modo whenever the octane plugin is enabled.
Also, whenever I disable the Octane plugin, I lose my menu bar at the top of the program (file, edit, ect)
Thomas
Thomas Alleman
3D Generalist
Those who get wisdom do themselves a favor, and those who love learning will succeed.
I will need to look into this. However it is worth trying deleting your Modo801.cfg file and re-trying with both plugins installed (you will need to re-authenticate the Octane plugin after doing this) - pls let me know if this resolves the issue.
Talleman
Thanks Paul. I'll give it a try and let you know how it works.
Thomas Alleman
3D Generalist
Talleman
Paul, this helped a little. I'm not getting the crash anymore, but the SubD Nurbs plugin still fails to work. It works great if Octane is not enabled.
Resetting the config file did help with the other issue of losing the menu bar, so that is a plus. :)
Should I bring this up on the SubD to Nurbs forum as well?
Thomas Alleman
3D Generalist
Thanks Thomas. Are you able to give me some more details on what is not working with Subd Nurbs? It sounds like it is probably an issue with that plugin, but if you give more some more info, I can send it to TF.
Talleman
Paul, below is the link to the screenshot of the error message.
https://www.dropbox.com/s/bkpnlbb4tbzbm ... 20fail.jpg
Thomas Alleman
3D Generalist
Return to “Foundry Modo”
