by the way face have you implemented the 'rendervis' flag yet?
Last time I checked it out it did not work.
Beta 2.2 RC1: SoftImage XSI plugin testing thread
Win7 Pro x64 | GTX 770 2GB + GTS250 512Mb | Intel Xeon i7 4x 3.4ghz | 16 GB ECC Mem | Intel SSD 520 | Dell 27"
SOFTIMAGE l 2011 + OCTANE V1.20
Should i?Amplitude wrote:by the way face have you implemented the 'rendervis' flag yet?
10 minutes to work
What should i export?
(visible, wichever rendervis or not) + (not visible and rendervis)?
go on, waiting...
http://vimeo.com/user2509578
no viewvis / no rendervis -> not exported
visible / no rendervis -> not exported
no viewvis / renderable -> exported
sounds good to me...
///// NEW UPDATE /////
You can download and read changes from the second post here.
Runs with the new 1.022 Final...
face
face
Thats while the exporter use the standart Softimage obj-export and subDs aren´t supported...adrencg wrote: ...A bad workflow issue for the exporter is that I have to convert my subD models to polygon, but even then, I'm not making nearly enough poly to get a smooth look.
But...
Mine will do that.
Which subD-Level you want to export, the render level or the OGL level?
I will test it with the OGL level first...
face
doca wrote:Oh, I'm sorry. I am running win7 64bit, Softimage 2010 64bit. Hardware: cpu quadcore 9550 3.7GHz, 8gb ram, Gainward 285gtx 2gb ram, Asus maximus formula motherboard.face wrote:Which windows/softimage version?doca wrote:Well, everytime I hit "render frame" button in the exporter, Octane crashes on startup. After 30 minutes of trying, I gave up. No succes. Octane crashes all the time on load, if it is called from Softimage.
How shows the crash, see the splashscreen from Octane, give Octane a messagebox?
More infos please, with octane crashes, i can´t work
Maybe fill your computer spects in your profile, that will reduce the question about it...
face
Whenever I want to export scene to Octane, and press "render frame" button, Softimage starts to export, but when I shoud expect Octane launching, there is a message that appears "octane.exe has stopped working". Here is what is written in problem details:
Problem signature:
Problem Event Name: APPCRASH
Application Name: octane.exe
Application Version: 0.0.0.0
Application Timestamp: 4bec2600
Fault Module Name: octane.exe
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 4bec2600
Exception Code: c0000005
Exception Offset: 0000000000003cc7
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1033
Additional Information 1: 2bb3
Additional Information 2: 2bb3152eda1a084fc7328dcbca38ff93
Additional Information 3: da01
Additional Information 4: da018f40d8add2fd0d9efd106ce50636
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid= ... cid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Does octane work without the script ?
Eg using our demosuite or another OBJ file ?
Radiance
That´s years old and fixed
The error was the spaces in the pathes...
face
face
I see, you have some parameters to choose when you want to export a subD...
From which construction mode should be the mesh exported? (modeling, shape, animation or secondary shape)
Which subD-level? (render or OGL)
Which subdivision rule? (Catmull-clark, doo-sabin, linear)
face
face
downloaded and installed the last version, neat !
but.... I have an issue when I try to specify the GPU device with the command line argument.
-g 0 -g 1
Octane crashes every time.
-g 0 -g 1
Without the -g.Amplitude wrote:downloaded and installed the last version, neat !![]()
-g 0 -g 1
0 1 2 3 4
face
