Cinema4D version 2021.1.4-(R4) (Stable 2021) 21.04.2022
thanulee
Here is a screen recording showcasing the navigation, indeed a bit hard to explain proper:
https://www.dropbox.com/s/iropzd1ydc2er ... r.mkv?dl=0
When I pan on the object location exactly it pans correct. When I pan anywhere else its super sensitive and object goes off screen very far. I am using Wacom pen, this is what I ve been using in previous octane versions as well without this behavior.
thanulee wrote:Here is a screen recording showcasing the navigation, indeed a bit hard to explain proper:
Clicked area is background I think. There's a multiplier factor to change the pan rate which is proportional to hit distance. Hit point distance should be very high if you click background
wangdanyang1120
aoktar wrote:
dasmodular wrote:Thank you! I tried that and it works, but it doesn't make sense to me.
Overall it is a great feature like every other one where the Octane plugin is working together with other third party plugins, but this still needs a little more usability.
Didn't you read my reply? My answer explains the issue. It's a new addons and with your helps it can be improved. But it simply works as in picture. Needs to put objects to tag as used group numbers
Well solved my problem! Thank you!
james_conkle
Is there a way to turn the snap to center feature off for the octane picture viewer? It seems to snap to center and on my small monitor that wastes valuable pixel space. (Smaller icons would be nice too but that would probably be a lot of work)
Also would appreciate the option to prevent the octane picture viewer from being able to move the render camera. Unless there’s a protection tag it can move the camera in a way that’s impossible to undo.
Octane C4D Plugin 2021.1 / C4D R25.015
UNIT 0: 2080ti / 6700K / 64GB / 500w
UNIT 1: 2x 3090 / 3970x / 128GB ECC / 1600w
UNIT 2: 5500M / 9980HK / 32GB / 95w
RNDR Artist Calculator
