OctaneRender® for ArchiCAD 3.03.3 [OBSOLETE]
Wonderful! I want it in the Revit plugin too
That is the plan - but after it's be tested in the ArchiCAD plugin.
I have refreshed the installers at the top of this thread with:
2.24.1.53
- For OCS/ORBX proxies source files, if a single mesh node cannot be found, the first "Geometry out" node will be used, and if that is not found whatever is plugged into the first rendertarget "mesh" pin will be used as proxy
- You can now edit the nodes and materials from OCS/ORBX proxies via the Edit button. This can only be done whilst the Viewport is open. IMPORTANT: This is experimental functionality, so use with caution. Make a backup of pla/pln files prior to using this function.
- Importing rendertargets and setting the rendertarget to default now correctly re-populates the Render Pass combo box
2.24.1.53
There was a problem with the installers for 2.24.1.53 which I have now fixed, and the installers have been re-uploaded. Pls re-download the installers and re-install if you had previously downloaded this release.
2.24.2.54
- Compiled with Octane 2.24.2
rappet
Thanx Paul
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
BfPuVAK
Hi Paul,
just installed 2.24.2.54 and got a 'Missing Add-on' error in Archicad :shock:
After reinstalling some of the older versions, everything is OK again - any idea?
Greets,
Artur
Win 10 Pro 64bit / Intel i7-6700 @ 4.0 GHz / RAM 32GB
2 x Nvidia GeForce GTX 980M 8GB (+ sometimes a GTX 970)
Archicad 21 4022 GER Full + Octane Render !
https://www.youtube.com/watch?v=7l7SefSWV98
http://www.youtube.com/user/BfPuVAK/videos
Hi Artur - can you pls reboot and try reinstalling the latest version. If you still get the error, can you post a screenshot of the Options->Addin Manager panel, with the missing addon selected.
Daniel_Ward
Hi Paul,
same problem for me too with the AC19 plug-in.
I've gone back to the previous build for the moment.
Edit - If you look at the Add-on manager it reports that the Plug-in is "out of Date"
Cheers, Dan.
+MAP Architects, Christchurch - New Zealand
ArchiCAD 4.12 - ArchiCAD 24 || Octane for ArchiCAD
i7-7700K - Gigabyte Aorus Z270X Gaming 9 - 32Gb RAM - 3x Gigibyte GTX1070 G1 Gaming - Window 10 64Bit
I have refreshed the installer at the top of this thread with:
2.24.2.55
- Fixed issue where plugin would not load, reporting "plugin out of date"
- Fixed crash when generating a grass ABC file for an object which was not previously a proxy
* NOTE: In AC19, when generating grass, the Mesh object that the grass will be placed on will be listed in the Mesh combobox by it's ID - which by default is blank. So enter a Mesh ID to name each Mesh, so that you can select the appropriate mesh to plae the grass on.
prehabitat
face_off wrote:I have refreshed the installer at the top of this thread with:
2.24.2.55
can we generate grass scatter files from within the Revit plugin?
Win10/3770/16gb/K600(display)/GTX780(Octane)/GTX590/372.70
Octane 3.x: GH Lands VARQ Rhino5 -Rhino.io- C4D R16 / Revit17
