That is the plan - but after it's be tested in the ArchiCAD plugin.Wonderful! I want it in the Revit plugin too
There was a problem with the installers for 2.24.1.53 which I have now fixed, and the installers have been re-uploaded. Pls re-download the installers and re-install if you had previously downloaded this release.2.24.1.53
- For OCS/ORBX proxies source files, if a single mesh node cannot be found, the first "Geometry out" node will be used, and if that is not found whatever is plugged into the first rendertarget "mesh" pin will be used as proxy
- You can now edit the nodes and materials from OCS/ORBX proxies via the Edit button. This can only be done whilst the Viewport is open. IMPORTANT: This is experimental functionality, so use with caution. Make a backup of pla/pln files prior to using this function.
- Importing rendertargets and setting the rendertarget to default now correctly re-populates the Render Pass combo box
Hi Artur - can you pls reboot and try reinstalling the latest version. If you still get the error, can you post a screenshot of the Options->Addin Manager panel, with the missing addon selected.just installed 2.24.2.54 and got a 'Missing Add-on' error in Archicad
can we generate grass scatter files from within the Revit plugin?face_off wrote:I have refreshed the installer at the top of this thread with:
2.24.2.55
- Fixed issue where plugin would not load, reporting "plugin out of date"
- Fixed crash when generating a grass ABC file for an object which was not previously a proxy
* NOTE: In AC19, when generating grass, the Mesh object that the grass will be placed on will be listed in the Mesh combobox by it's ID - which by default is blank. So enter a Mesh ID to name each Mesh, so that you can select the appropriate mesh to plae the grass on.
