OctaneRender® for Poser beta WIN - build 1.16a [OBSOLETE]
mlru
Found a vestige from the charset problem:
Changing an image and select it from the [Octane Image Files] list brings up this error:
Traceback (most recent call last):
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 1155, in <lambda>
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 1857, in EventNodeChanged
TypeError: descriptor 'rfind' requires a 'unicode' object but received a 'str'
The other lists do work.
Uwe
Win11/64Bit | GTX 4090 24GB | NVidia Driver 546.29 | Octane 4.05 | DAZ Studio 4.21
mlru
And another one.
Happend after I added a prop and used the morphing tool in PP2014 on a V3, not sure, what's the cause:
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\__init__.py", line 72, in Render
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\UiManager.py", line 3542, in ShowSetupForm
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\Configuration.py", line 131, in LoadSettings
File "D:\Programme\CGI\Poser\Poser Pro 2014\Runtime\Python\lib\xml\etree\ElementTree.py", line 1177, in parse
tree.parse(source, parser)
File "D:\Programme\CGI\Poser\Poser Pro 2014\Runtime\Python\lib\xml\etree\ElementTree.py", line 653, in parse
parser.feed(data)
File "D:\Programme\CGI\Poser\Poser Pro 2014\Runtime\Python\lib\xml\etree\ElementTree.py", line 1624, in feed
self._raiseerror(v)
File "D:\Programme\CGI\Poser\Poser Pro 2014\Runtime\Python\lib\xml\etree\ElementTree.py", line 1488, in _raiseerror
raise err
xml.etree.ElementTree.ParseError: not well-formed (invalid token): line 1, column 163
edit: OK, and now I get this error everytime I try to open the plugin, no matter what's in the scene. It's broken. :|
Uwe - the config.xml file has become corrupt. Can you pls send me a copy of it (in C:\Users\[username]\AppData\Roaming\Poser Pro\10) and then delete it. You should then be able to run the plugin. I will also change the plugin to handle this situation better.
I will fix this in the next release.
RGUS
Just a silly little request....
Can we have the focus returned to the node edit cell when for instance one picks 'gamma' say the focus of the dialogue box automatically goes to the edit cell so we can start entering numbers without having to first pick that cell... did that make sense... hmmmmm
WEB: http://rgus.deviantart.com/
GPU: NVIDIA GeForce RTX 3090 Ti
RAM: 64GB
CPU: 12th Gen Intel(R) Core(TM) i9-12900K 3.20 GHz
OPERATING SYSTEM: Windows 11 Pro
OCTANE PLUGIN VERSION: 2025.6.0.4.80 Prime
DAZ STUDIO VERSION: 4.24 Pro Edition (64 bit)
Do you mean when you focus pick? This was in an early version, but I pulled it out because having the keyboard focus change from the Viewport to the Setup window when you focus picked meant the tree position moved, and this got quite confusing. Also, focus picking and then the plugin automatically selecting the focus "number" edit box would mean if you mousewheel scrolled, the focus would change and that would be unexpected, since intuitively you would think that the Viewport still had the focus. Hope that makes sense....
RGUS
Yeah... like in the earlier versions... I wasn't confused by it... now when the rendering is going on, changing a setting on the fly takes ages to highlight the value you want change and the numbers take ages to change what you typed. The only way around this is to pause the rendering, make the change and start the rendering again.
RAM: 64GB
Are you running a separate card for your Windows adapter? If not, are you running "Low Priority" in the Cuda Devices tab?
RGUS
Yes separate adapter and yes nvidia card set to high... I think I need a titan... if that's the best card, I can't seem to find out definitively what the best card is for still image Octane rendering.
RAM: 64GB
I'm not able to reproduce the GUI performance issue you are experiencing. Is it only on big scenes? If I do anything on the plugin Setup window whilst rendering, I pretty much get an instant response.
RGUS
27" LCD 2560x1440 resolution 60Hz 32bit colour DVI interface
RAM: 64GB
Return to “Poser”
