Octane 2026.4 for Cinema4D - v1.9.4
@y81r:
The issue is reproducible and we will look into it, thanks for the report!
@Kalua:
Sorry, ORBX export works as expected here.
Is it happening in any scene or only in one particular scene?
Have you tried to export via Render Settings/OctaneRender/Main tab?
ciao,
Beppe
Kalua
bepeg4d wrote: Mon Aug 10, 2026 1:16 pm Hi,
@y81r:
@Kalua:
ciao,
Beppe
I will give it a try.
Thanks, Beppe
C4D 2025.3.3 Octane v1.9.4 // Octane SA 2026.4, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
rrbarb
Cinema 4D 2026.3
OctaneRender Studio 2026.4
Windows 11 Pro 25H2
NVIDIA driver version: 591.86
2X GeForce 2080Ti
C4D Commamdline 2026.3.4 + Octane for C4D 2026.4-1.9.4
Commandline 2026.3.4 hangs/crashes
Roll back Octane plugin Octane for C4D 2026.4-1.9.3
Commandline 2026.3.4 renders successfully
Hello, I have discovered that with 1.9.4 plugin: Commandline hangs(STDOUT.txt)
Tried with range of file complexities. 1.9.4 always hangs at same point.
With 1.9.3 Commandline runs with no issues.
We are running Command line to render farm through Deadline and OpenCue.
Failures through either were confirmed directly in CMD outside these managers.
I have sent STDOUT.txt in PM
ChrisHekman
rrbarb wrote: Fri Aug 14, 2026 12:34 pm Cinema 4D 2026.3
Windows 11 Pro 25H2
2X GeForce 2080Ti
We cannot seem to recreate the hang. Could you share a scene with us that exhibits the commandline hang?
rrbarb
I uninstalled 1.9.4. Re-Downloaded both windows exe and archive. Installed and tested from both-> No Commandline hang !?!?! :oops:
Test files ran as expected from CMD and from render managers.
ThankYou for your attention to this matter.
./rrb
