Octane 2026.3 for Cinema4D - v1.9.3
Tim0042
bepeg4d wrote: Thu May 28, 2026 10:41 am
Sorry, I cannot reproduce the issue.
Output AOVs are untonemapped, so you need to apply the same color conversion with layers, to obtain the same result you have in Main pass, and Live View color dropdown menu shouldn't have any effect on Output AOVs :roll:
Could you share an example scene that shows the issue?
ciao,
Beppe
Hey Beppe, thank you for replying! Of course, I agree that LV color dropdown shouldn't have an actual effect on the exported Output AOVs. But when showing an Output AOV within the LV, what would be the harm if the LV view transform was respected? That is the behavior for all the other passes. (EDIT: excluding the "info" ones, but reflection, refraction, etc.)
The context is: I'm trying to do some grading directly in Octane, so I'm running the Main Pass into an Output AOV. As a clean starting point, with no grading applied, I need these two to match when viewed in the LV under a sRGB: ACES view transform. That is currently not possible, as the LV transforms one but not the other.
The solution, as you say, is to add a "convert for SDR display" node in the Output AOV graph, so I can accurately preview my composite in the Live Viewer. The problem is: That transform is then permanently baked into the final EXR on render. So I need to disable the node before any export, then later enable it again for further look dev.
So I was looking for a way to avoid this type of workflow and/or hear that I misunderstood something about how the plugin currently handles this, which is very possible. I can share a scene, but we may be describing the exact same behavior. : )
What about using two Output AOVs?
One with color correction for Live View preview, and the other without it for compositing in post.
You can use the same nodes connected to both Output AOVs, and add the color correction only on top of the first one.
ciao,
Beppe
Tim0042
bepeg4d wrote: Thu May 28, 2026 2:28 pm What about using two Output AOVs?
ciao,
Beppe
That would work, true - though it would then save two output AOVs into the multilayer EXR? Unless I manually disable the preview one before rendering, but that would be similar to manually switching the node on/off each time. I could use multiple render settings, but changes to the Output and Render AOVs in one would not be automatically reflected in the other.
The extra clicks are not the end of the world, of course, but long term I would like to add this as a feature request: Have the LV apply its view transforms to Output AOVs in the same way as to the main pass.
If Output AOVs typically contain a "main pass + compositing", then having their LV presentation match would be consistent and remove a gotcha. And in cases where an Output AOV is used as more of a data/info pass, we can still set the LV view transform to none. In both cases, there would be no risk of accidentally changing an export setting, as this is purely an LV display thing.
Overall, still not fully wrapping my head around Octane + Color, but I'll keep at it : )
Anlv
After updating Cinema 4D to version 2026.3, a compatibility issue appears to have occurred. When launching C4D, it gets stuck at `Initializing Plugins 33%` and cannot enter Cinema 4D. Removing the Octane plugin restores normal functionality.
Supplement: After I removed the OctaneRender directory inside AppData, it returned to normal.
3D Motion Graphics Designer / E-commerce Designer
13700K / 64GB / 4090 / PSU 1250W
Anlv wrote: Tue Jun 16, 2026 7:53 am After updating Cinema 4D to version 2026.3, a compatibility issue appears to have occurred. When launching C4D, it gets stuck at `Initializing Plugins 33%` and cannot enter Cinema 4D. Removing the Octane plugin restores normal functionality.
Great to hear you have already solved!
And yes, this could happen with Non-Latin Windows operating systems.
Happy GPU Rendering!
ciao,
Beppe
Kalua
Currently running with an issue with a scene.
never seen it before since V1: am rendering in liveview window, I open the material nodes to edit shades, as I scroll down the nodes list with middle mouse button, it tends to freeze the mouse and Windows. Screen goes black and eventually system reboots.
I am not running Chrome or other apps that conflicts with 3d graphics.
2nd time it happened now... Is like Windows doesn't recognize Nvidia drivers anymore...
32" screen with crappy resolution...
am investigating what to do.
But never had issues before like this.
seems to be a really horrible stepback il with my work.
Update 1: rebooted and all ok.
I may rollback to avoid this issue.
will give another try....
Update 2: now screen goes black randomly... Will invert the 2x3090 positions if it persists.
Update 3: Maybe Discord Hardware acceleration had something to do.
still testing.
Update 4: no... Things keep happening.
as I render in LV window, I open image node to change an image and as explorer opens, Windows freezes... Reboots...
should I DDU graphic Driver?
What driver do you guys consider stable atm?
C4D 2025.3.3 Octane v1.9.3 // Octane SA 2026.3, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
Anlv
Kalua wrote: Mon Jun 22, 2026 11:11 pm Currently running with an issue with a scene.
still testing.
Use the Studio driver instead of Game Ready. I have never encountered any issues with it, including on the 4090/4070 Ti.
The current driver version is 610.62.
I previously ran into a similar issue where the system would freeze and become unresponsive, followed by a black screen. It was eventually resolved by replacing the monitor's cable.
Kalua
Anlv wrote: Tue Jun 23, 2026 12:52 am
still testing.
Thank you
I am using Studio Drivers. I believe it is a matter to use the one that is more stable to your system.
About the cable... Idk... Could that be it?
Funny it happens usually at similar instances. And cable is the Samsung cable it came in the monitor box.
Thanks again for the insight.
Anlv
Kalua wrote: Tue Jun 23, 2026 1:06 am
still testing.
Thank you
You're welcome. Drivers are indeed the first thing that needs to be checked, but if no driver updates have been done recently, I would rule that out (you can usually check the driver date in "Device Manager").
As for cables, I used to think official cables would be better too. But sometimes certain manufacturers just cut costs in places where they really shouldn't.
Kalua
Actually... I think found the issue.
Sure I upgraded the driver to latest.
But also, I had to take my Desktop with 2x3090 + Nvlink to a meeting last week.
Put the big case in its original box with protective foam and all stuff.
Untill yersterday, I didn't realize The Nvlink dropped from both GPUs... XD
That could have triggered some issues since Nvidia conf is set to use the SLI thing.
Anyways. Things running smoother again.
