OctaneRender® for 3ds max® v2026.1 - 26.04
HHbomb
Even without inverting, it crash... It is a 16 bits tif image.
paride4331
HHbomb wrote: Mon Jan 19, 2026 10:23 am Even without inverting, it crash... It is a 16 bits tif image.
Hi HHbomb,
I was able to reproduce the issue on my side. It doesn’t occur consistently, but under certain conditions I’m able to trigger a 3ds Max crash. I’ve forwarded my full report to the development team.
Regards
Paride
HHbomb
Thanks ! :-)
paride4331
HHbomb wrote: Tue Jan 20, 2026 10:44 amThanks ! :-)
Hi HHbomb,
The issue will be fixed in the next release. Keep in mind that the issue can also occur when changing the timeline, even without any animation.
Regards
Paride
coilbook
Can you please release an update so ty flow terrain will render in octane? Thank you
terra.rar
(89.22 KiB) Downloaded 62 times
HHbomb
Strange. It works for me
coilbook
HHbomb wrote: Tue Jan 27, 2026 11:15 am Strange. It works for me
Do you have a sample scene by any chance? Thank you!
HHbomb
I just use a preset flow and add a Terrain Mesh. I use max 2022 by the way
neonZorglub
Hi coilbook,
Currently, to use a TyFlow terrain, you need to disable the Particle interface.
terra_ParticleInterfaceDisabled_mx21.zip
(122.16 KiB) Downloaded 62 times
I'll see if that can be avoided in a future release.
@HHBomb : Thanks for checking. I suppose you also have Particle interface disabled ?
HHbomb
@NZ : yes I have Particle interface disabled.
I enable just when I have a lot of particles.
Can you tell us when Particle interface must to be activated ? :-)
