R 13 and exporter
colorlabs
This happens to me after 20-50 frames (though usually 21 frames for some reason). Every scene I've tried.
Mac OS X 10.8.0 | ASUS GTX 580 1.5GB | MSI GTX 470 | ATI Radeon 6870 | Core i7 2.9Ghz | 16GB
abstrax
Ok, let's do it the other way round: This scene doesn't exhibit the problems you have described. Does it work on your puter, too?
bouncing.zip
(170.86 KiB) Downloaded 334 times
Marcus
hi marcus,
i've tried to render a 200f animation of one of my scenes with r13 and export 11c with no problem, than i've tried with your and octane hang on at 183f, i had to end the process to make the exporter working again. :(
abstrax
Thanks Beppe. On which setup did you export/render the scene? Which OS, which GPUs, which drivers and which of the GPUs were used for display and which for rendering?
Has anyone else tried that scene?
Marcus
On the pc, see the signature, 2x590, 4 GPU for render and also 1 for display, no over tasks, only octane.
If you want i can render it with only 3 GPU and leave the last one only for display :roll:
abstrax
bepeg4d wrote:On the pc, see the signature, 2x590, 4 GPU for render and also 1 for display, no over tasks, only octane.
Yes, could you try that please.
Marcus
ok, with 3 gpu and one for display, octane doesn't hang on but on the mac i have two videocard (one for display and one for octane) and with a very simple animation sometimes it failed and sometime not.
it seems very difficult to reproduce the problem :(
Obviously doesn't happen with r12 and 1.252
Proff54
abstrax wrote:Ok, let's do it the other way round: This scene doesn't exhibit the problems you have described. Does it work on your puter, too?
bouncing.zip
Marcus
Hi!
With this scene render stops on the first shot: " Rendering of frame 1 failed. Trying again (5/5) ".
I 4 times started render over again - result former.
The most interesting, that render goes and even the result is save, however the plug-in writes: " Could not render frame 1 on 2011! " And on it all comes to an end.
On my scenes the stop occurs absolutely in different cases on the same scenes.
The problem is not solved.
Forgive for my bad English.
I7 3930K 6 Core+HT 3,3 Ghz / 64 GB Ram / GTX690 for Octane / Quadro4000 for display / Win 7 64 Bit
Proff54
Idea.
If to disconnect a computer from Internet, such problem does not arise. Now I use such method of the miscalculation of animation.
Respectfully, Anton.
I am sorry for bad English.
GearCG
Any update on how Octane for R13 is going?
Windows 7 Home / GTX 460m / i7 740qm / 8GB / C4D r13 and ZBrush 4.2
