WIP Lighting Challenge #22: The Carnival
Proupin
yes, the extreme dof makes it look like a miniature... wouldn't be possible to take this shot with a normal lens (with a tilt-shift lens you could)... I don't know if you have to adjust the scale, perhaps adjusting the aperture would suffice
livuxman
Thanks Proupin, i will try to better adjust the DOF, but for now I have been adding geometry and textures. The next one will fix that problem and hopefully there will be a new version with the linux hdr problem solved and I can finish lighting.
Here is the latest version.
LiVux 64bit | Geforce GTX260 Core 216 and GTX470 | i7 860 | 8Gb | Drivers 275.09.07 | Cuda 4.0.17
FamilyGuy
Was it your intention to do a render looks like Barbi funfair. If not its something wrong with the DOF. It looks like a small model of big funfair.
radiance
I was thinking this was going to be a very dificult chalenge to do good with octane render in it's current feature state, but you're starting to suprise me ;)\
keep it up :)
Radiance
yijian4515
:o How long for this render? and what's your Graphics?
livuxman
Radiance, thank you very much, I will keep fighting trying to improve the result and if possible, surprise you a little bit more :-)
@Yijian4515, the previous render were 10minutes, the new has been 20minutes. My machine is a QuadCore Q9300, GTX260, under linux.
I modified a bit the scene to not look so miniature, but I shall continue with it.
yijian4515
Wow,it's so cool。i think I have not the speed of this renderer to play out completely. :D :roll:
pixym
livuxman wrote:Radiance, thank you very much, I will keep fighting trying to improve the result and if possible, surprise you a little bit more :-)
I take part of the people liking "mininiature" look :geek:
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10
Net render : MB Asus Pro WS W790E-SAGE SE - XEON - 128GB - 2 x RTX 3090 - 3 x RTX 2080TI
[gk]
you should give the baloons some transparency, they currently look like they weight a ton each :)
increase the DOF, its out of balance and the background doesnt blend in that good.
Work on the wetness look on the street that isnt covered in wate ( the difference between water and dry land is way to strong )
keep em comming.
Amiga 1000 with 2mb memory card
livuxman
Thanks [gk], pixym and yijian4515 for all yours comments.
@[gk] I tried to give more transparency (now have 0.9) and did not like the result, sss would need to improve. As for the rest, I'm at it, but with problems.
@pixym, model is really miniature, although I have been changing a lot the look, scale remains as miniature. I have not yet clear what will be the final appearance or if make two versions.
In this version I've basically been working on fixing some problems in geometry (smooth some areas and correct some errors), and I encountered a serious problem, because when increase slightly the number of triangles, I found that the scene has left working, which has complicated the process. (I'll explain more in another support post)
Return to “Works In Progress”
