AOVs Question
neonZorglub
HHbomb wrote:Hi NZ !
Thanks a lot for these explainations ! :-)
I read and read again octane prefs and I didn't see this dammed checkbox ! It must be said that prefs are bigger and bigger ! (ok, it was on the first page...)
what about :
In octanerender viewport you can "export passes selection to render elements", but it don't work with AOvs...
Strangely, you can "export passes selection to clipboard" and then AOVs are taken into account.
Hi HHbomb,
That's right, the Preference dialog is becoming a nightmare.. I have plan to redo it some day, with a Simple / Advanced mode to hide rarely used settings, and a maybe search box.. Sorry about that !
Thanks for signaling the "export passes selection to render elements" not working for AOVs, I'll try to fix it in a next release.
BenterA
Thank you very much for all your efforts and your help, neonZorglub! It works now :)
HHbomb
"the Preference dialog is becoming a nightmare.. I have plan to redo it some day" : good luck ! :-)
Return to “Autodesk 3Ds Max”
