OctaneRender 2022.1.1.0 Solaris 19.5.569 RC1-[OBSOLETE]
Octane output ignores the render resolution.
- Attachments
- solarisPortrait.zip
- (109.23 KiB) Downloaded 108 times
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
It seems that the composite material isn't being correctly exported via usd since when loading it it in Standalone, the materials are missing. It works fine when loading it straight back in Solaris.
- Attachments
- usdCompositeMat.zip
- (1004.38 KiB) Downloaded 133 times
Hi Rohan,rohandalvi wrote:Thanks.BK wrote: Hi Rohan,
Thank you so much for reporting this.
We are able to replicate and hope to get this fixed in the next release!
cheers
Just to ask the question again. Would it be possible to use a custom render target in Solaris, if not, would it be possible to implement it?
Yep, we had this workflow for a while. It looks like still working.
Please find the attachment
Kind Regards
bk3d
bk3d
- rohandalvi
Thanks for the file.BK wrote:
Hi Rohan,
- rohandalvi
I was wondering if the spotlight controls can be added to the standard octane houdini plugin or is it something that can only be done in Solaris.
galleon27 wrote:Octane output ignores the render resolution.
Hi galleon27,
Thank you so much for reporting these issues and for the sample files.
We have reported via our internal ticket system.
Hope we can fix it for the next release.
cheers
Kind Regards
bk3d
bk3d
Hey Rohan,rohandalvi wrote:I was wondering if the spotlight controls can be added to the standard octane houdini plugin or is it something that can only be done in Solaris.
Sorry, do you mean adding Solaris Spotlight parameters in Sop workspace?
We seem to support all the Octane lights including the Toon lights.
cheers
Kind Regards
bk3d
bk3d
Cryptomattes aren't written out when using "Override Output Image" in the USD Render ROP (Other passes seem to work correctly, might need to test more to make sure I'm not missing something)
Cryptomattes work correctly when using the Octane > Output > Output Picture option in Render Settings
When I try to render out animations from Solaris, it doesn't render. Render Current frame works fine - opens Mplay and renders. The Render sequence fro Octane LOP does nothing, and if I connect a USD render LOP it saves empty frames. May be I am doing something wrong?
Another question, do you plan to release a Linux version?
hi Peter, thanks for reporting this.peteg wrote:Cryptomattes aren't written out when using "Override Output Image" in the USD Render ROP (Other passes seem to work correctly, might need to test more to make sure I'm not missing something)
It seems the cryptomatte AOVs are created on the Octane side, however, all the AOVs are flattened with USD Render ROP.
Is it okay to use Octane's Output while we investigate the "Override output image"?
cheers
Kind Regards
bk3d
bk3d
