A Broken Displacement After Export to RNDR.
Aleksei wrote:
bepeg4d wrote:...if you select it and go to Live View menu Materials/Convert material, it will be converted to Composite Material...
Does this mean that the Mix Material is deprectaed and I should use only the Composite material in such cases?
Yes, Mix Material has several limitations in C4D, works only with 2x materials, it needs to work in conjunction with 2x other node materials so it is difficult to move it in another scene, it doesn't work in C4D Content Browser, and doesn't work correctly with Solo mode.
Composite Material solves all these limits, and it works correctly with Solo mode too.
ciao,
Beppe
