World Creator 3
mikefix
Also waiting on Lightstage.
Singular1974
Literally been waiting half a year.
HandcraftedMedia
Any updates?
Vector6
I would also like to know.
I subscribed to World creator directly and just discovered I had been billed twice 3 times.
Waiting on their response Atm. But it's a kick in the balls when it should be included here by now.
Aaron
Turck
Wait, I just subscribed to 1 year Enterprise+ and you tell me that we don´t have access to the latest World Creator edition?
And what about Lightstage? In the description it said s.th. about access to the 3D scans.
Terryvfx
Any news about when or if we are getting the lastest version of WC3?
dynaraton
FYI, World Creator 2022.2 for Octane is available. Thanks Otoy!
Asus Prime Deluxe II : Intel i9-10900 X : 128GB G.Skill 3600 MHz DDR4 RAM : (1) Nvidia RTX Pro 4500 Blackwell, (1) Nvidia RTX TITAN: Win11 Pro : Latest Cinema4D
MyRho
Yes - thank you.
Unfortuantely it's crashed and it won't start again. :(
MSI MPG Infinite X2 MSI GeForce RTX 4090 24 GB VENTUS Intel i9 14900KF
Nihil sum sine sole.
GXGsynth
why is World Creator 3 not available except for those who purchased on Black Friday, despite the main OTOY site promising:
all paid Octane subscription tiers starting at just 13.95 €/month (with Black Friday discount), including annual passes to: Greyscalegorilla Plus, LightStage MetaFace scans – a preselected free kit from KitBash3D every month – and full commercial licenses to World Creator, EmberGenFX, Architron, and Sculptron.
Embergen works, Sculptron works, Architron works, the Kitbash3D codes work, yet there's a "not licensed" error when opening the normal version of World Creator 2022? (GreyscaleGorilla plus doesn't work either, I dug through the fine print and found that it's only "annual" subscribers that get access, and even then only people who signed up last year, I emailed them and got no response)
World Creator for Octane basically broken, it doesn't export screenshots at all, and needs to be told what folders to export to every time the program is opened, the rotate functionality doesn't pivot around anything in particular, etc.
even then, the only thing I can get it to export is an orbx file with a greyscale exr displacement map attached to a plane and an extremely convoluted setup of an RGB image -> multiply texture -> diffuse material layer -> diffuse material, which contains no roughness/spec/normal/or any other texture file, so even water is just a blue diffuse surface, despite "IncludeMaterials" being set to ON.
neither image can be used outside of the orbx file, unless there's a way I'm unfamiliar with of extracting files from within an orbx container. so for all the awesome capability World Creator seems to have from the demos I've seen, it's rather useless in terms of actual functionality in the Octane version...
you can open the WC3 .orbx in Standalone, and use the Unpack package command, to obtain an Assets folder with all the maps:
ciao,
Beppe
