OctaneRender 2020.2 LightWave Production build 2020.2.5.1
Lewis
Carlos3D wrote: R: Octane has always been like this in any version.
It shouldn't be an Octane issue but rather a LightWave limitation...
I believe!...
No, sorry Carlos, that is not what I'm describing there, people are probably missing key point here, INSTANCE polygons are used just for placing instances (imagine you have Polygons 2*5m with shorter edge and you use 100 of those to place car son the car park, you don't want those polygons (placeholder for car position and direction) to be visible eon render, you just want CARS that are instance don top of those. So CAR are ON in scene editor, but placeholder polys are OFF in scene editor.
Currently, in 2020.2.5.0 that is not possible/working while in all other previous versions it DOES work that way.
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
Mastoy
Nope, I've been using this simple trick for a long time now (using deactivated "support" geometry for instances)
That's a problem if it's broken in this new version
NemesisCGI
Lewis is right, this use to work. Tested in Octane 2020.2.4.0.
Confirmed: If you hide the instancing object in this case a cube the instances still render in older versions.
Shaun.
Win 7 pro 64bit GTX780
Carlos3D
I believe!...
R: Hmm now I realized
Sorry for my point of view
Tx Carlos
pixelsmack
Can you set polygon size to ZERO for that intancer placer? As a work around?
Lewis
pixelsmack wrote:Can you set polygon size to ZERO for that intancer placer? As a work around?
What if you use "polygons size" option :)?
P.S. I know some workarounds but regardless this have to be fixed.
Lewis
Skype - lewis3d
ICQ - 7128177
promity
how about the beta version of octane 2021 for lightwave - does it exist at least for the "elite" who are allowed to beta test?
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
hdace
Very much looking forward to the MacOS version.
Vote for Juanjo!
promity
promity wrote:how about the beta version of octane 2021 for lightwave - does it exist at least for the "elite" who are allowed to beta test?
Strange - such a simple question, but still no answer. At the same time, beta versions have already been released for all other packages. Should we consider, in this case, the lack of information for 2021 for LW as a signal that the development for Lightwave will be discontinued?
Lightwave 3d
juanjgon
I've updated this topic adding a new 2020.2.5.1 build including a fix for the bug in the instancing rendering introduced in the previous version and the macOS build.
