PoserOctane_studio.dll could not be loaded
maldowns wrote:2021-05-20 19:58:34,138 OctaneRender for Poser log
2021-05-20 19:58:34,528 Python Version : 3.7
2021-05-20 19:58:34,528 Platform : win32
2021-05-20 19:58:34,528 OS Architecture : 64bit
2021-05-20 19:58:34,528 Poser Version : 12
2021-05-20 19:58:34,528 Poser App Version : 12.0.500
2021-05-20 19:58:34,528 Plugin Version : 2020.2.0.106
2021-05-20 19:58:34,528 OctanePlugin.py = D:\Program Files\Runtime\Python\addons\OctaneRender\OctaneWrapper.pyc
2021-05-20 19:58:34,528 OctaneDefaults.py = D:\Program Files\Runtime\Python\addons\OctaneRender\OctaneDefaults.py
2021-05-20 19:58:34,528 Loading Octane library D:\Program Files\Runtime\Python\addons\OctaneRender\Windows\PoserOctane_Studio.dll
2021-05-20 19:58:34,528 Paths
2021-05-20 19:58:34,528 D:\Program Files\Runtime\Python\addons\OctaneRender\Windows
2021-05-20 19:58:34,528 D:\Program Files\Runtime\Python\PoserScripts
2021-05-20 19:58:34,528 D:\Program Files\python37.zip
2021-05-20 19:58:34,528 D:\Program Files\Runtime\Python\DLLs
2021-05-20 19:58:34,528 D:\Program Files\Runtime\Python\lib
2021-05-20 19:58:34,528 D:\Program Files\Runtime\Python\lib\site-packages
2021-05-20 19:58:34,528 D:\Program Files\DLLs
2021-05-20 19:58:34,528 D:\Program Files\Runtime/Python/lib/python3.7
2021-05-20 19:58:34,528 D:\Program Files\Runtime/Python/lib/python3.7/site-packages
2021-05-20 19:58:34,528 D:\Program Files\Runtime/Python/lib/python3.7/site-packages/wx
2021-05-20 19:58:34,528 octane.dll: date/time = Thu Feb 4 20:33:46 2021, filesize = 50345472
2021-05-20 19:58:34,528 PoserOctane_Studio.dll : date/time = Mon Feb 8 16:36:04 2021, filesize = 194560
2021-05-20 19:58:34,528 octane.dat: date/time = Thu Feb 4 20:21:22 2021, filesize = 169915272
2021-05-20 19:58:34,528 Current Directory = D:\Program Files\Runtime\Python\addons\OctaneRender\Windows
2021-05-20 19:58:34,638 Octane library failed to load
2021-05-20 19:58:34,758 Poser builder number = 500
2021-05-20 19:58:34,758 addon:__init__
2021-05-20 19:58:36,608 addon:load
Sorry for the grief you are having with this. There have been no other reports of this issue, and I know STUDIO users are working fine with this release.
I suggest you try the following:
1) Install Octane Standalone 2020.2.3 and confirm that it renders by adding a rendertarget to the canvas and clicking on it, and then checking there are no errors in the log (this will confirm that your Nvidia drivers are up to date and installed correctly
2) Make sure you install the latest version of the plugin (2020.2.3.108).
3) The above log indicates that everything is setup OK, and that Poser is /trying/ to load the plugin, but the octane DLL is not loading (this is generally due to your Nvidia drivers not being up to date). However, there is a slight possibility that the fact that Poser is installed on the D: drive is causing the issue, so you could try reinstalling on C: and see if that resolves the issue.
Let me know how you go.
maldowns
does the stand alone need to be updated?
will a lower version plugin work in poser 12?
i really need to get back to my production today or I need to work the alternative as above, sorry for my impatience but I am on the verge of an income from my art and need to get cracking cheers
maldowns
ok thanks I try what you have suggested- I just checked my gtx980ti 's are up to date as far as i can tell, i hit update and the drivers came back the same
maldowns wrote:does the stand alone need to be updated?
Test your Nvidia drivers are work with Octane Standalone 2020.2.3 please. And update the Poser plugin to the latest release.
maldowns
installed the octane stand alone as you suggested, opened it up it did not see my cards, so i manually installed a new nvidia driver for my cards direct from nvidia, it said installation for driver failed but i opened stand alone again and it and my cards showed up in the devices setting, so i opened up poser and it came up with a box telling me to click here install nvidia CuDnn for octane to work........and yippee ki ay !@#$% octane works in poser 12 and I am back in business
I am still shouting you at the pub cheers mate
maldowns wrote:installed the octane stand alone as you suggested, opened it up it did not see my cards, so i manually installed a new nvidia driver for my cards direct from nvidia, it said installation for driver failed but i opened stand alone again and it and my cards showed up in the devices setting, so i opened up poser and it came up with a box telling me to click here install nvidia CuDnn for octane to work........and yippee ki ay !@#$% octane works in poser 12 and I am back in business
Good to hear - glad that you are back up and running.
Return to “Poser”
