Will the RTX 3080 work in Octane 4.05-R7?
v4 is based on CUDA 10, so you need 2020.2-XB5 based on CUDA 11.1, to have the full RTX 30X0 support:
viewtopic.php?f=33&t=76196
You also need to upgrade the Nvidia driver to 456.38 or greater, with a clean installation.
There is also a a new cuDNN library that needs to be installed at first start:
ciao Beppe
salvation
So you mean that my V4 license is now useless and the simplest way to render my ocs-files is to rent a OctaneRender Studio Subscriptions ??
Thats sad.
Win7 64 | Geforce 470GTX 1280MB | Q9550 2.83GHz | 8GB Ram | NVidia 306.23 , Cuda 5.0.1
Goldorak
salvation wrote:So you mean that my V4 license is now useless and the simplest way to render my ocs-files is to rent a OctaneRender Studio Subscriptions ??
Thats sad.
No - you should get maintenance (go to buy-Upgrade-> section on shop page) which gets you on to 2020+ at about half off the monthly Enterprise sub price, but with all ent. sub features and extras (all dccs, Embergen Beta, ORC, RNDR, etc.) using your perpetual V4 license.
tegatwork
Hello, I'm about to upgrade my rig. I'm planning to by 4*3080 but I was asking to myself if it would be better to get those 4*3080 or 2 or 3*3090 with nvlink? what's the best for Octane?
jimho
tegatwork wrote:Hello, I'm about to upgrade my rig. I'm planning to by 4*3080 but I was asking to myself if it would be better to get those 4*3080 or 2 or 3*3090 with nvlink? what's the best for Octane?
for a 4 card configuration,usually you will need a double(slot)width card, but seems there is no such 3080 sold at the moment,only Gigabyte provides 3090 turbo which could be used for a multi GPU workstation...
Supermicro 4028GR TR2|Intel xeon E5 2697 V3| windows 10| revit 2019 |Titan V+ Quadro GV100+RTX 2080 Ti
tegatwork
Yep, I know, it's not my forst 4gpu rig. In fact, I've got a Level20XT case from Thermaltake and 2 of my GPU are "suspended" with risers. Not a problem to get bigger cards, then.
Timmaigh!
salvation wrote:just got a RTX 3090 and Octane 4.05 is not working. :(
It shows me in the preference:
CUDA version: 11.10
Device: Gefroce RTX 3090 (compute model 8.6)
But at the bottom of the Viewport stands in red "no CUDA GPUs"
How can I now render my old Standalone files?
Same here! Luckily i kept one my old 2080Ti´s, so i still have capable hardware to render, but please, fix ASAP!
R9 7950x, 64GB DDR5 6000 MHz, 2x RTX 4090, Samsung 990 Pro 2TB, Kingston KC3000 2TB, Kingston KC3000 1TB, WD Caviar Gold 6TB, Win11 Pro 64bit
ivolodkov
Hi! Is there any solution now? 4.05-R7 still not working with RTX3090.
Timmaigh!
ivolodkov wrote:Hi! Is there any solution now? 4.05-R7 still not working with RTX3090.
I dont think its happening :-(
Buchanero
Same here. New Nvidia Founder RTX 3090 and it's refusing to save out any image - unless i just select save out from the live viewer. Nothing in the render queue works / saves out. RTX isn't enabled and neither is Denoising. Renders perfectly well in the live viewer though.
**edit** I'm a moroon. I had denoiser toggled in the camera tag but miussed it...unticked that and it started saving.**edit**
Has anyone got an idea of when this issue will be addressed??
