OctaneRender 2020.1 for Houdini Beta build 2020.1.0.6 RC4
galleon27
Planetary Environment is missing from the render target hda. Can you add it? Its been probably missing since it was added as a feature, i just noticed it now.
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
juanjgon
galleon27 wrote:Planetary Environment is missing from the render target hda. Can you add it? Its been probably missing since it was added as a feature, i just noticed it now.
Ah, yes, probably the RenderTarget HDA has not been updated, but the planetary environment VOP node is there, so you can link it yourself to the render target if you need to use it.
galleon27
Yea i found it and it works. The HDA just needs an update.
Thanks.
Sacha.wech
Hey thanks for this!
Any news on the universal camera? What's the roadmap for implementing this for Houdini?
Cheers
juanjgon
Sacha.wech wrote: Any news on the universal camera? What's the roadmap for implementing this for Houdini?
We are still discussing how to implement this camera on the plugins side due to the fact that it is not a conventional Octane node but a scripted node graph. There are going to be some changes related to this node in the Octane SDK, perhaps adding these same features to the current camera nodes, so I'll wait for them before adding this camera node to my plugins (or update the current camera nodes with the missing parameters).
caseyhupke
I saw you posted a new build of the RS plugin that enabled full proxy export. Does that mean Octane has that feature coming soon too?
juanjgon
caseyhupke wrote:I saw you posted a new build of the RS plugin that enabled full proxy export. Does that mean Octane has that feature coming soon too?
Yes, this feature will be available in one of the next builds.
