Hello? Will it be fixed?
Apart from this what tags can be used?
$OCTANE_PASS$ is one we know that works. Are there any other?
[21.x] New octane output issues, continued...
C. RAM Capacity (i.e. 6 GB)
System – Windows 11
System – Windows 11
Bump
Any update on this? I'd like to be able to completely control the naming convention on how my files are output. I don't want the default "[OctaneExport]" to appear in front of my numbered sequences. Or if I do put my own text in there, then I don't want the default "_Combined" pass name appearing at the end.J.C wrote: 3. Standalone tags are not working. Are there any other tags we are not aware of?
Win 11 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
Those bugs look like unsolvable issues as there is no comment whether they will be solved or not. Really strange :/
System – Windows 11
System – Windows 11
- linograndiotoy
You can actually specify any Prefix in the Octane Prefix field. I normally use it to specify the filename; any string will work.pegot wrote:BumpAny update on this? I'd like to be able to completely control the naming convention on how my files are output. I don't want the default "[OctaneExport]" to appear in front of my numbered sequences. Or if I do put my own text in there, then I don't want the default "_Combined" pass name appearing at the end.J.C wrote: 3. Standalone tags are not working. Are there any other tags we are not aware of?
About the Suffix, I normally use $OCTANE_PASS$_### (for animation shorter than 1000 frames).
Don't specify any filename in the Output Path, just the path of the folder you want your renders to be saved to.
So, if you specify MyRender_ as Prefix and $OCTANE_PASS$_### as suffix, your file name will be MyRender_OctBeauty_096.EXR for example.
If you also specify the file name in the Output Path, you'll get MyRender_FILENAMEOctBeauty_096.EXR
You have quite a good control on customizing file names.
Thanks Lino for clearing this up. Where can we expect updated manual with all those undocumented features?
System – Windows 11
System – Windows 11
- linograndiotoy
Not sure. I'm not directly involved in documentation.J.C wrote:Thanks Lino for clearing this up. Where can we expect updated manual with all those undocumented features?
