Cinema 4D version 2020.1-XB3-R2 (EXPERIMENTAL) 12.02.2020
Studio21 wrote:Ty ahmet..Vol shadow ray step should also be there though. so there is still a parameter missing
thx
You'll find it if you uncheck "lock step length pins". I've improved the gui for usage
Studio21
thx
Oh, i see now :)
thx!
fractaledvisions
This version shows up as 2020.1_XB2-R2 in the Octane Dialog, and won't let me use network render with Enterprise Slave Daemon 2020.1_XB3, but Slave Daemon 2020.1 XB2 works. FYI
SSmolak
When render stats in settings tab is turned off, all stats are moved to out of view in Live Viewer window. They are partially visible at the top side of LV window.
SSmolak wrote:When render stats in settings tab is turned off, all stats are moved to out of view in Live Viewer window. They are partially visible at the top side of LV window.
any screen shot please
SSmolak
R21.xxx? which one?
J.C
There is missing Render Layer's rendering mode – "Hide From Cameras"
Only three modes are available in Cinema plugin. In previous 2019 it is also missing.
https://docs.otoy.com/StandaloneH_STA/S ... Passes.htm
System – Windows 11
SSmolak
aoktar wrote: R21.xxx? which one?
Latest R21.115
J.C wrote:There is missing Render Layer's rendering mode – "Hide From Cameras"
I fixed it for next build, thanks!
