overexposed picture when using hdri
John_Do
Thank you for the quick feedback Lino.
It was already off since I was using the Camera Imager override in the viewport. I tried with the own camera Imager settings but the result is still the same.
You can see all my CM settings in this screenshot, do I miss something ?
First one is Viewport Render.
Second is Final Render.
We can see that Octane viewport display right and wrong result whether it's a preview or a final render.
I'll ask if it's possible to set the Display to none by default. We need to consider a user may have the standard Blender version installed already, so changing its configuration file could be a bad idea.
I've totally missed that, you're right. So a warning / splash screen at first launch could be a solution.
J.C
John_Do wrote:Thank you for the quick feedback Lino.
Your settings look ok. Do you have "Prefer tonemap if applicable" enabled in server settings?
Can you send your file from the screenshot above?
System – Windows 11
John_Do
I forgot this. I've enabled it and now the renders match. Thank you !
Return to “Blender”
