NoLFedit wrote:Is there some way to see what the increase/decrease is like in the standalone for RTX?
Cinema 4D version 2020.1-XB1-Test2 (EXPERIMENTAL) 10.12.2019
Hello,
I'm trying out the new version but I get following error when I render in the live viewer:
perhaps someone knows what this cause?
Tried to access pin via an invalid ID P_INDEX (80)
Tried to access null node pin
Can't write float to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFD83F23870)
Failed to allocate page-locked memory
are you trying a big scene? Looks like a memory error due to out of core!crush4 wrote:Hello,
perhaps someone knows what this cause?Code: Select all
Tried to access pin via an invalid ID P_INDEX (80) Tried to access null node pin Can't write float to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFD83F23870) Failed to allocate page-locked memory
Hello, yes it's a very huge scene but it was running without problems with the 2019 versionaoktar wrote:are you trying a big scene? Looks like a memory error due to out of core!crush4 wrote:Hello,
not surprising, this is an experimental development build. It will help to find the issue if you mind to share your scene.crush4 wrote:Hello, yes it's a very huge scene but it was running without problems with the 2019 version
Very stable and it opens older projects no problem. Nice!
A couple small things that I'm assuming weren't implemented in this build:
- Couldn't find the ACES options or OCIO display management options
- the new OSL procedural materials won't download into a project.
Thank you again, Aoktar, for your great work. And the entire team at OTOY.
I've sent you the scene in a private message. Perhaps you can also take a look on my scene setup? I'm very new to octane.aoktar wrote:not surprising, this is an experimental development build. It will help to find the issue if you mind to share your scene.crush4 wrote:Hello, yes it's a very huge scene but it was running without problems with the 2019 version
I didn't included ACES yet, I wished to put a build asap for testing RTX feature because I heard a lot of swearing about we didn't offer that. I'll add missings and fix some uncomplete parts in this period.BCres wrote:Very stable and it opens older projects no problem. Nice!
Mean OSL version of C4D shaders?
- Deltaproxy
Hi, testing the new c4D plugin on a complex scene - when RTX is activated - it takes longer than when not active..
and in both cases the render comes without certain lighting and scatter objects.
Am I doing something wrong or is just my scene?
(NVIDIA Studio Drivers up to date, C4D version R21.026, Octane version OctaneRender Studio 2020.1 XB1)
i7 9600k CPU
64 GB RAM
2x2080ti GPU
i7 9600k CPU
64 GB RAM
2x2080ti GPU
