keyframe HDRI rotation?
protovu
Thanks, Chris.
That was it.
If we could figure out a live update it would be perfect. My in and out of the preview is slow. Possibly because of mesh compilement.
But thankfully, another fine tune in the toolbox thanks to you.
Rick
Whispermode
ChrisH wrote:I thought "This could probably be solved with an OSL script!"
And so it could! :)
Chris - you are my hero. :P
J.C
You can use traditional keyframing to achieve this.
1. Attach Full Transform Node to Image transform input.
2. Change Translation X value to desired number.
3. Hover mouse over Translation pulldown (not over X, Y or Z value) and press "I" key to insert a keyframe.
4. Change Translation X value to desired number and set keyframe like in step 3.
Checkout attached example:
envRotation.blend
(13.03 MiB) Downloaded 207 times
System – Windows 11
J.C
J.C wrote:You can use traditional keyframing to achieve this.
You can also do this with any node that has pull down menus with values. The trick is that you have to set keyframe while hovering mouse cursor over pulldown selection name, not a specific value.
System – Windows 11
protovu
Happy, happy, joy, joy!
Thank you, JC. It even has the live update!
Whispermode
J.C wrote: You can also do this with any node that has pull down menus with values. The trick is that you have to set keyframe while hovering mouse cursor over pulldown selection name, not a specific value.
...Amazing, J.C - also my new hero.
Return to “Blender”
