firefly-less firefly
kubo
thanks, really, it means a lot coming from all of you guys.
I've done a couple extra renders tweaking the lights to see if I could get better results from PMC, but as you can see, (firefly 15) in PT it looks better for some reason, and I'm certain that in the first tests PMC was doing better, also this last ones got out a little grainier, so I've downsized all 3 to half. Specs on the filenames
PMC, no color correction, I let it cook for some time, yet I couldn't achieve the desire result. Halfsized
PT much faster and less samples, yet it looks better than PMC. Color corrected and halfsized.
I was moving the camera and found this shot, I had to let it cook. PT, color corrected and halfsized
9fly
Your second set makes me think it's your reference photo for first set. OMG, how can you do that with the fur (?? i dun know how to call it) outside of firefly wings and body.
Most of all this is awesome man.
p3taoctane
One of my favorites to come out of the octane.. Very cool idea and very well implemented.
Briliiant!!
kubo
thanks guys, btw the "fur" is just a thin base triangle scattered over some areas with 10k instances with a grey glossy .7 opacity material (white shows up too much and black can't be seen) the whole mesh with a turbosmooth of x2 on the body and the "hair" is under 80k triangles. I'll improve the hair with a blurred texture that it'll look better for close ups.
ello
really nice. i specially like the glowing ones. great work!
win7,i5 760 6gb,gf 460 1gb
my cinema4d plugin collection for creating complex random or ordered structures and more: http://plugello.earthcontrol.de
Hawker
quite fun.
a i am so bored and tired of those *ù$@ architectural renders that it is a pleasure to see other things like that.
jcm21
Great work. I'm curious... what program did you use to create the model and rig?
Win 7 x64 / GTX460 2GB / 8GB ram
Jaberwocky
well if he was using Turbosmooth , my guess is 3DS max.
kubo
thanks all for your kind comments, and yeap Jaber is spot on, 3dmax was used for modeling and rigging.
