Cinema 4D version 2018.1-RC6.1 (Test version)
moebius
How to work with Cryptomatte?
I get different results in LV and Picture-Manager. And how can I "Mask" specific objects?
Silverwing
Hi Ahmet.
I have a weird issue with materials in this built whenever I work with bigger scenes that have a lot of materials.
Problem:
When I create or copy a octane material and assign it to an object some other objects randomly switch to another materials.
Example:
I have a white cube a red sphere and a green pyramid.
I create a new blue material and assign it to the white cube.
Now the cube is blue. But the green pyramid suddenly becomes red (or any other available material)
The tag of the pyramid is still the green material. But in the rendering the pyramid is rendered red. Also after I reassign the material, after reload the render to the GPU or even restart C4D.
It probably does not work with simple scenes with 3 objects like above.
Usually I have a lot of instances in the scenes.
The material assignment is showing up correctly in C4D. And even when I reload the problem persists.
The only way to fix this is to cut and paste the material that should be signed to the object and then reassign it.
Sorry that I do not have a simple test scene...
I can send you a scene via Skype if you want as I can´t share it publicly.
I will make a video of the behaviour when I have the time.
WIN 11 PRO 64 | ASUS X299 SAGE | 1X RTX 4090 3X RTX 3090 | i7 10980XE | 128GB RAM
anklove
Silverwing wrote:Hi Ahmet.
Problem:
Example:
I have the exact same problem which i explained on page 1
i7 10700k | Win 10 64 bit | RTX 3090
Kalua
Problem:
Example:
I had this problema as well in recently removed V4 R5. Aoktar already found a way of fixing it. Probably will know how to do it as well for V2018.1.
C4D 2025.1.1 Octane v1.9.3 // Octane SA 2026.3, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
bagel
So since Standalone RC6 and presumably final version is back to 2 GPU rendering, is RC6 plugin allowing more than a single GPU? I can't enable my second GPU, no errors, I can set it, but then it just unselects itself. Any idea on when final version is coming and will it support 2 gpus?
bagel
bepeg4d wrote:Hi,
c4doctane 2018.1-RC6 Studio already supports 2x GPUs:
ciao Beppe
*sigh*
Don't mind me. I'll go be dumb somewhere else. I made a mistake in which plugin I currently had installed. Thanks!
divasoft
This version not work with cinema Volume builder. I start render and nothing happens. VDB Volume object does not work same.
VVG
divasoft wrote:This version not work with cinema Volume builder. I start render and nothing happens. VDB Volume object does not work same.
all ok
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
divasoft
all ok
No, you don't understand me. Why did you use Volime mesher? I talked about Volume Builder only and vdb loader. Try it
