Viewport slow when ipr rendering
Houdini Integrated Plugin
juanjgon
How are you moving the camera? Directly interacting with the camera viewports, or using the camera object handlers for another perspective view or using the camera node parameters? Really it's hard to figure why something like that could happen, especially with the camera update, that is a very simple operation.
I'm going to make more tests to see if I can see something like that here. One good test to see if the problem can be related to the Houdini OpenGL viewports (somehow interacting with the Octane rendering) could be to close all the Houdini viewports and change the camera transformations directly using the camera node parameters.
Luther76
Hi Juanjo,
I tried to move the camera in every ways (on the viewport, with keyframes, with the camera node parameters...) but nothings change. I also tried to close the viewport scene and move the camera with the parameter, but nothing.
I did a video recording of my screen to show you what happen on my workstation with the IPR in houdini.
here the link:
https://vimeo.com/303680663/603810e22b
As i wrote, I use, in the same workstation, octane for cinema 4d and works fine, so I think is not a problem of hardware, drivers or windows settings.
Paolo
blobbybarack
Sorry to highjack this thread guys but i think this is related in some way.
If i use camera handle : fast update as expected.
If i scroll values with middle mouse or if i change value in cam parameter with numpad : fast update as expected.
if i move camera with viewport with space bar : delay between houdini and octane.
could be great to have auto update with the third scenario.
juanjgon
Well, when you move the camera in the viewports, the camera is not updated until you release the mouse button. The problem is that Houdini is not reporting the camera parameters changes and the change event until you release the button. A complex workaround to extract the viewport camera transformations in realtime is possible, but it is not available yet in the plugin.
@Luther76, can you please send me the complex scene to make some tests with it here? You can pm a link to download it if you want.
Luther76
Hi Juanjo,
do you have some news about my IPR trouble?
Paolo
juanjgon
I'm still working on it. It seems that somehow sometimes disabling the deformations "D" button in the IPR window doesn't disable the object updating at all, not sure why. It is like Houdini were cooking the object for each frame, but after playing a bit with the slow updates, the scene becomes faster, as you can see in the attached video.
2018-12-06_11-52-33.mp4
(29.89 MiB) Downloaded 2884 times
blobbybarack
Do you have any expressions links or null or chop or whatever on your camera ?
Luther76
Hi BlobbyBarack,
Yes I do, the camera is linked to a series of null (to control the single rotation). I don't have any expressions.
Why do you ask me that? Any suggestions?
Cheers
Paolo
blobbybarack
You can't have an instant feedback with this scenario as Houdini need to reevaluate real camera position at some point before sending it back to octane. I could be wrong, Juan need to confirm this.....it's just a theory. I'm too lazy to check it right now.
juanjgon
I've found a weird behavior that could be a clue about the problem. The IPR updating in your scene (with all the four update options disabled, of course) works fine while scrubbing the timeline if you leave the IPR fully render one frame, until complete all the samples. From this point, all works fine ...
Return to “Houdini”
