Motion Blur does not work with Takes
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
DinoMuhic
KeeWe wrote:
DinoMuhic wrote:I just tried it with baking the cameras first. It still didn't work.
Did you try my scene?
Yeah thanks a lot for that. I tried it and it works in your scene.
I checked my scene again and the only difference I found was that the scene is set up in 50fps but its being rendered in 25fps.
While this worked with Motion Blur using the Picture Viewer Render it did not work with the Take rendering.
Setting it up to 50fps worked though. So that was the culprit.
However there are still some bugs concerning MB and takes which really need to be adressed for this system to work flawlessly. I don't get why there is this discrepancy between Render to PV and Render Takes to PV.
Thanks a lot again!
I cannot check your case for a while because I'm off. But I wouldn't call it as bug because most likely it's not implemented and supported. But you're free to call it what ever you wish.
Return to “Bug Reports”
