Some minor bugs (rhino 6)
please, take a look at this short video I made. The bug of "camera visibility" doesn't seem to be resolved. As you can see if I re-load the file while rhino is running, everything works. But If I close rhino and re-open the file the bug is still there.
This is happening because you are doubleclicking the .3dm file in order to start Rhino, and the relevant triggers are not being fired to catch the loading of the plugin data. Instead, start Rhino, then File->Open the .3dm file. I have pushed this issue to McNeel to see if there is a way around it.
fabrizio_s
Hi Paul,
I tried to open file inside rhino but nothing is changed
fabrizio
Can you send a video pls? I just double checked this and it is definitely working for me.
fabrizio_s
Hi Paul
here you can download the video I made
http://s000.tinyupload.com/index.php?fi ... 1922798602
bye
The problem here is that you are loading the file from the splash screen. You need to load via the File->Open menu option in Rhino6. From what I can tell, this is a Rhino6 bug, which I have notified McNeel of.
fabrizio_s
Hi Paul,
I tried to load the file from splash screen, from file-open menu, from everywhere but it's the same :-)
fabrizio
You are right again! My apologies for the trouble I am having resolving this issue. I think I have now got it right. Can you pls test the pre-release subscription version at https://render.otoy.com/customerdownloa ... IPTION.rhi
fabrizio_s
Hi Paul and don't worry: it wasn't a crucial bug in the workflow.
This new version works fine! Thanks a lot
fabrizio
Return to “Rhinoceros 3D”
