This was a basic design decision in the current version of the plugin: all texture images are copied into the plugin's working space so they can be saved as part of the SKP file. This was based on user feedback from earlier (2.x) releases: a common complaint was the inability to move an SKP file that included an Octane version of the model to a different computer without losing the texture information, unless you carefully copied all the temporary texture folders generated by the plugin into the correct places. We do realise that this often creates very large save files as an unavoidable side effect, but there's really no way around it if we want portable SKP-with-Octane files. We may add an option to allow users who are aware of the consequences to disable this behaviour; the save file would then remember only the local path to a texture file instead of copying the actual file, which if I understand correctly is what you would prefer.johlanga wrote:I think that if i chose a link path to my texture folder/structure it should not be modified by the plug-in and cram every texture in one temp folder. This are also a problem when exporting to standalone I have to relink every texture
Thanks for the extra information about your other issues; I'm looking into these.
