OctaneRender™ 3.0 for LightWave™ - Test build 3.08.0.7 RC1
Bugstomper
BorisGoreta wrote:It appears that image sequence with F10 does not get saved. Switching to LW renderer the sequence gets saved.
I confirm the issue, image sequence is not saved, that's quite annoying.
kopperdrake
Thanks Juanjo - great news! Coinciding with the new bug-fix release of 2018 this gives me the impetus to finally open 2018 :)
- web: http://www.albino-igil.co.uk - 2D/3D Design Studio -
- PC Spec: Intel i9-7940X @3.1GHz | 64Gb | 3 x GeForce RTX 3080 Ti & 1 x GeForce RTX 2080 Ti | Windows 10 Pro 64-bit -
gordonrobb
Thanks for this.
I'm having some problems though. To be sure I wasn't doing anything stupid, I downlaoded the 2018.0.2 update so that I was starting on a new install.
I downloaded the Plugin.
I made sure I extracted the 2018 version
I coped the files you need to copy and put them in the bin folder (as normal) of the 2018.0.2 install
I added the plug in
I installed the menu tree.
This is where the first thing happened, this duplicated all my existing menues (see image).
Also, when I go to the octane tab, I don't see any of the tools (see image)
Any ideas?
UnCommonGrafx
It took 3 attempts for it to stick, for me.
I didn't follow the procedure of quitting and restarting on at least one of the attempts.
Or, as happened for me, on the third try, I deleted the menus and re-added them: everything showed up.
i7-4770K, 32gb ram, windows 8.1, GTX Titan and gt 620 for display
promity
Any ideas?
- uninstall LW, delete all config's, install lw again.
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
gordonrobb
promity wrote:
Any ideas?
It happened with my already installed 2018.0.1. So I downloaded and installed a clean 2018.0.2 and it was the same. So this is with a completely clean install.
juanjgon
In LightWave 2018 all the images must be exported from the passes node, including the beauty pass. The new LightWave 2018 buffers system is not supported yet.
juanjgon
The same, you must export the images using the path/file options available in the passes node, like if you were working with the Standalone. The LightWave 2018 buffers system is not supported yet.
juanjgon
gordonrobb wrote:Thanks for this.
I added the plug in
Any ideas?
Hmm, you don't need to copy any file to the LightWave bin folder, this was a really old install procedure. All the needed files are now located in the same place used by the plugin .p file, so you only need:
- Extract the plugin folders from the .zip file to any HD location.
- Add to the Layout the plugin .p file (the one for your LightWave version)
- Add the menu branch
You don't need to make anything else and you don't need to copy anything to the LightWave folders.
Hope this helps,
juanjgon
vipvip wrote:is it normal to have to reactivate the plugin on www on every new LW session ? this was not the current behaviour before...
thanks,
Nope, here you don't need to reactivate the plugin again. Are you trying to enable the plugin in offline mode, because currently this mode is not available yet.
Return to “Lightwave 3D”
