GPU Failures
Moderator: ChrisHekman
ChrisHekman
Lewis wrote:
ChrisHekman wrote:
Lewis wrote:Hi guys,
This is for v4 in general? Also for standalone?
Could you export the unity scene as an orbx and load it in standalone and see if the error persists?
Hi Chris
Sorry i should explain it better, this is not really Unity only related, happens to me in LW plugin and in standalone. I think it's something in general octane core (i can't make 100% reproducible scene, sometime happens 5 times a day sometime works 5 days no problem) what triers that error (as you can see on forums there is several of users from various apps/dcc plugins have that error so it's not really strictly to unity only.
Sorry one more time for confusion thinking it's unity-Octane only issue.
I understand. I advice you to post the error at the Commercial support forums.
viewforum.php?f=10
Since it seems to be GPU related, the best option is to post the error in the GPU Support forum
viewforum.php?f=11
coilbook
has anyone found out why. I am getting the same cuda errors for no reason. After these errors happen octane would reboot and continue rendering but after 5 times it is done and stops rendering.
fis715
I just want my money back they keep charging my account and i cant use Octane i keep getting all gpu's failed error no response or help from Octane or Unity this is bad
ChrisHekman
fis715 wrote:I just want my money back they keep charging my account and i cant use Octane i keep getting all gpu's failed error no response or help from Octane or Unity this is bad
For license issues you should go to viewforum.php?f=10
On your GPU error issue. I have already asked you what your errors are, and if you could tell me when they occur, but you have not replied.
rokklancnik
I have a similar problem. Except that the error on cuda says 999 and not 700. And something with the ORC subscription.. here is the LOG:
__________________________
Started logging on 04.03.19 17:48:58
OctaneRender Prime 4.00 (4000021)
ORC user subscription status could not be retrieved: The server returned a client-side error with HTTP code: 401
ORC subscription status cannot be found
CUDA error 999 on device 2: unknown error
-> failed to link file
device 2: failed to load OSL shader code:
error : Multiple definition of 'cuSptStatistics' in 'cuda_texturenode', first defined in 'snippets_internal'
device 2: failed to compile module 0
___________________________
scottbroad
Has there been any further development on this issue? ...
I can use Standalone ok but in Unity I still get the error:
CUDA error 999 on device 0: unknown error
device 0: failed to load OSL shader code:
device 0: failed to compile module 0
It would be good to be able to use Octane again in Unity ...
WIndows 10, GTX 1060 6Gb, Octane 4.02.1 - Unity 2018.3.8, OctaneRender Prime 4.00 (4000021)
Clive Broadhurst
Win 10-64bit, i7-3770K, 16Gb, GTX970
Revit 2015, Blender
ChrisHekman
Hi Scottbroad,
This is an nvidia driver issue. We are working on a build that fixes this, it should be out soon.
Return to “Unity”
