Raised edges for geo-grafted prop
Moderator: BK
sinfulsecrets
Thats my problem. Even without the body present I have the same issues. It does not matter what it is. All geo grafted props give me the same issue. Wings, Tails, inhuman limbs. All have the same problem of varying degrees.
Can't get anything right...
cyprine
an easy solution is to remove the displacement node completely.
3feet's procedural material uses the torso maps of your model and chances are it doesnt have a displacement map.
details are present in the normal & bump maps.
and unless you are rendering a close up, there wont be much of a difference.
wader
sinfulsecrets wrote:Thats my problem. Even without the body present I have the same issues. It does not matter what it is. All geo grafted props give me the same issue. Wings, Tails, inhuman limbs. All have the same problem of varying degrees.
Hm, I seem to be having decent luck with most grafted props I've tried and this issue was resolved (per earlier in the thread) by adjusting the offset.
Do you have an example (e.g., name of prop/product and how it's being used) we could try out?
Windows 10 Pro 64-bit | Ryzen 9 5950X | ASUS Pro WS X570-ACE | 64GB |{ASUS ROG Strix GTX 3090 24GB + (2x) Titan X Pascal 12GB}
If there is a definite solution for this issue, can you please describe it here in detail, and I will then copy/paste that text into the FAQ section of the manual so all users benefit.
abayliss
Apologies if I'm late adding my two cents to this thread.
I have experienced a similar issue with displaced geo-grafts that had nothing do do with displacement maps. I found it was only happening when Daz Studio was in the geometry editor tool mode. When I switched back to the universal tool, the geo-graft would become seamless as expected.
Windows 10 Pro 64bit, i7-8700 3.2 GHz, 64GB RAM
2 x RTX 2080ti
Return to “DAZ Studio”
