GPU not running at 100%
stefano-dear
bepeg4d wrote:Hi Stefano,
what are the specs of your machine?
Are the same as your signature?
Can you share the scene used for testing?
Hi Beppe,
These are my specs:
iMac - 4GHz i7 - 24 GB RAM- OSX 10.12 - 2x GTI 980 Ti - 2x eGPU Thunderbolt Bizon BOX - C4D R17
Here you can see the speed difference with the same scene.
I have uploaded the scene here:
https://we.tl/vJ5xZjCNyU
Thank you
Stefano
Hi Stefano,
thanks for sharing the scene.
I'm quite sure that the issue depends on your setting in the Devices tab, and in particular, the Priority option:
with Priority Low
with Priority Low
no Priority
no Priority
Probably in Standalone the Priority option is disabled or set to High, so the GPUs are used almost at full power.
P.S. what are you using to get the GPU graph under Os X?
stefano-dear
The attachment Screen Shot 2017-06-29 at 12.11.01.jpg is no longer available
The attachment Screen Shot 2017-06-29 at 12.16.44.jpg is no longer available
Thank you very much Beppe!! The issue was the priority setting :)
For the GPU graph under Os X I use iStatmenu, if you select the processor of the GPU, you can see the graph.
Thank you
Best Regards
Stefano
stefano-dear
Now I have an another issue :(
I'm rendering a very big image, 6622x4677 px but the two graphics cards work one at a time! :shock:
See the video:
https://youtu.be/CG8Rwq_JT9A
Why is this happening?
Stefano
Hi Stefano,
what about system RAM?
Could you share the scene with me?
stefano-dear
Unfortunately I cannot share this scene because it's a scene of an work in development.
However seems to be no problems with the RAM
Stefano
ssokol
Same problem for me with 4090 in Standalone Octane... any help?
this discussion is quite old, sorry, what is exactly your issue?
Please, download and run GPU-Z:
https://www.techpowerup.com/gpuz/
And share a screenshot from the Graphics Card tab, for Nvidia RTX 4090 GPU, thanks.
Please, also go to c4doctane Settings/Devices panel, press the Device Settings button, and share a complete screenshot of both panels, thanks.
Then share another screenshot similar to this:
ciao,
Beppe
ssokol
sorry,
I placed same question here viewtopic.php?f=36&t=81126&p=422113#p422113
So I will answear there,
thanks
I don;t use Cinema, only Standalone version of Octane
bepeg4d wrote:Hi,
ciao,
Beppe
