Version 3.06-TEST4.1 (WORK IN PROGRESS BUILDS)
stefano-dear wrote:Hi aoktar!!
First of all, thank you very much for you work!!
It is normal that now I see the node editor over the Live Preview?
You should not see this. It was for my debug purposes. Are you on OSX?
You can disable it from Settings/NodeEditor/NeDebugging
stefano-dear
Yes, I'm working on OS X. Thank you, solved!
mrom
Sorry for my question, I was searching quite a bit in the forum and didnt find anything. I think this occured in the latest versions.
If I import a png24 with alpha and put on a plane via image texture: all good.
But if I import the same file as a .psd, I have to crank up the gamma for the image texture in the opacity channel to 8 to get rid of a nasty edge - disable partial alpha and pre-multiply don't do anything. I tried with photoshop cc 2014 and the latest.
What could be my mistake? Or what did change and how can I adapt?
Thank you!
psd png.rar
(816.7 KiB) Downloaded 316 times
milanm
@eyeonestudio
Check if 'Auto Load Materials' is enabled in Octane settings. For me, gestures didn't work without that enabled.
Regards
Milan
Colorist / VFX artist / Motion Designer
macOS - Windows 7 - Cinema 4D R19.068 - GTX1070TI - GTX780
milo_dude
Building geometry by spline using Sweep. When geometry update starts plugin is crashed.
Same trouble in test3 and 4.
3.05 works fine.
Test_3-06.rar
(493.41 KiB) Downloaded 315 times
octane 3.06 TEST 4 170325 131749.log
(11.67 KiB) Downloaded 300 times
mrom wrote:Sorry for my question, I was searching quite a bit in the forum and didnt find anything. I think this occured in the latest versions.
Thank you!
Have you checked on standard renderer? I did that seems like a problem with outlines in psd.
milo_dude wrote:Building geometry by spline using Sweep. When geometry update starts plugin is crashed.
3.05 works fine.
Yes it's crashing the renderer. We'll investigate it.
milo_dude
3.05 works fine.
Thank you so much! It will be great!
mrom
aoktar wrote: Have you checked on standard renderer? I did that seems like a problem with outlines in psd.
Thanks for getting back to me on the weekend, aoktar. It seems to be the case, but take a look at the attached file please:
The texture is a png (just a filled layer, I cut out the middle in Photoshop and scaled it down) - I made an octane and a c4d texture.
The cut area renders perfect, around the outside is a white fringe.
If I render in standard renderer, the white fringe from the c4d shader disappears (as it should), in octane it stays.
What could be the problem?
Thank you so much, I am getting a bit confused here ;)
black png.rar
(70.92 KiB) Downloaded 304 times
Shading of image_texture in standard render that's not interpolated by any filters. It's implemented just for preview purposes and that's not high quality. So that's not expected results from a renderer. Standard material with starndard renderer is expected result. Because pixels are interpenetrated on line at from white to black. So you have to see a outer color on edges as you see.
