Hmm, the problem related to the freeze after aborting a render should be fixed in the Octane test4 API. Is there anything special in these scenes, like a composite background or something like that?
Slow performance?
This is pretty ridiculous.
I have a scene that I rendered in 5k resolution. It has a coomposited background. Rendering took about an hour. But from 99% to final render, it took also about an hour to finalize the render.
After 15 minutes of waiting I would have liked to abort task, but then I would have to re-render the scene...
And are you sure that if you remove the background or any other LW compositing functions the render works fine? I've found that the render can be a bit slower if the compositing functions are enabled, but I can't understand the final delay of about 1 hour!
For the next build (that I'll release in few days), I've added an option to disable the preview image while rendering using F9/F10. This should improve the rendering performance of scenes with large render resolutions or with the LW compositing functions enabled. Please test it with your scenes to see how it works.
