C4D crash to render 16000 x 16000px image
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
zamak wrote:At 16000 x 16000px for me
So that's a core problem. Maybe about environments.
We'll look for that. Can you try a different way as clipping to small parts.
zamak
With c4d I can do a render at 11000px no problem, but from 12000px there is bug inside image or crash. Very strange....
zamak wrote:With c4d I can do a render at 11000px no problem, but from 12000px there is bug inside image or crash. Very strange....
Yes i tested at different sizes. This is a core issue i suppose. Need to be reported to Otoy guys.
zamak
Do you mean render région? Because I have same bugs or crash for 16k rendering
zamak wrote:Do you mean render région? Because I have same bugs or crash for 16k rendering
As i can see you're using linear buffer so it has no vignetting. You can render it with a tiling script as 8k. I remember that was mentioned somewhere.
zamak
Yes but I tried tonemapped buffer to for the same result.
abstrax
Disable post-processing. Here it works, but post-processing takes a long time to calculate due to the image size and the large number of glare rays. At a resolution of 16K x 16K the post-buffers use 2.5GB on the device, and making the film buffer available on the device for tone mapping / post effects requires that 4x 1GB of memory are page-locked and mapped into device memory. All things together probably run into some limitation or time out.
In a nutshell: If you've got insane render sizes, don't use post-processing.
We are working on moving the whole tone mapping and post processing pipeline to the host (CPU), but until then the size for which you can apply post effects is limited.
zamak
Ok THX I'll try that!
zamak
i tried, no cuda error, and the rendering began but after 60s c4d crash.... :cry:
zamak
After much testing, I have the impression that 11Kpx is the limit for c4d with or without post production. From 12Kpx there are aberrations and splits rendering ...
Return to “Bug Reports”
