I have added some code that should fix a possible scene corruption while working with the multi-thread scene extraction mode enabled. I think that the reported problem could be related to this issue.
Losing obj parameters
C. RAM Capacity (i.e. 6 GB)
Hi everyone,
Sorry for my english.
I have exactly the same problem.
But i understood that this problem come each time i restart my computer.
If i don't restart my computer, there is no problem.
I f i restart my computer, spare parameter explode or are deleted .. and i need to take a backup.
If you want, Juanjgon, i can send you my file.
And perhaps, if you restart your computer, you will find this problem!?!
I'm really stressed and i need to animate a mix material.. but each day , when i restart my computer , all is erased or crash.
Please, can you help me?
in fact, i Don't know why my file crash..
i send you this..
perhaps you will understand.
each day, all is broken… And i must all restart..
when you clic on camera, you will see that all is broken.
I think everything comes from the materials, i used in "metalChargeA" a mix material.. but i need to animate this.. and my problems begin..
i send you this..
Really I don't know what could be the problem in your case. Can you please send me your .hip file to try to reproduce the problem here? ... I'm lost with this issue. I can't reproduce it here, and it makes no sense at all.
Only one question, are you working with the latest plugin builds?
I have this message if i Promote parameter in materials
WARNING: OPUI_DialogPRM2: Symbol "l.labeltext" value stepped on.
WARNING: OPUI_DialogPRM2: Symbol "l.expr" value stepped on.
WARNING: OPUI_DialogPRM2: Symbol "l.jive" value stepped on.
ERROR: C:/Users/User1/AppData/Local/Temp/houdini_temp/diaFEA8.tmp (1061): Failed to add child gadget.
i have all my file recreate.
all was perfect.
1 day after,, without modifications.. i have crash and error
curly brace.
<internal> Error(400): disablewhen: Conditional doesn't start with an opening curly brace.
<internal> Error(408): disablewhen: Conditional doesn't start with an opening curly brace.
<internal> Error(416): disablewhen: Conditional doesn't start with an opening curly brace.
<internal> Error(432): disablewhen: Conditional doesn't start with an opening curly brace.
<internal> Error(441): disablewhen: Conditional doesn't start with an opening curly brace.
<internal> Error(452): disablewhen: Conditional doesn't start with an opening curly brace.
<internal> Error(476): disablewhen: Conditional doesn't start with an opening curly brace.
<internal> Error(487): disablewhen: Conditional doesn't start with an opening curly brace.
all was perfect.
curly brace.
i send you my file without problems, and my file corrupted.
Please, help me.
Thanks a lot
Please, help me.
Thanks a lot
- Attachments
- DEMO BUG.7z
- (191.47 KiB) Downloaded 799 times
