OctaneRender™ Standalone 3.05.3
paride4331
Elvissuperstar007 wrote:add function mirror texture (X.Y)
https://docs.otoy.com/#rManuals
Regards
Paride
TheImageFaculty
Hi Guys,
I have an animation where the camera orbits around a product and we are using the Shading Normals pass for relighting in post.
The issue we have at the moment is that the normals are not 'aligned' to the camera. This means that as the camera travels to the rear of an object, the relighting needs to shift to another colour.
So I am requesting a 'camera' space normal pass as an alternative to the 'world' space shading normal pass we currently have. If you have a work-around in the meantime I'd be interested to hear it.
Darren
The Image Faculty ApS
https://theimagefaculty.com
Elvissuperstar007
Regards
Paride
parameter scale -1? it looks like something strange and uncomfortable
Zay
When copying a color or a number in the Node Inspector and paste it to another node in the Node Inspector, it gets updated in the viewport - but not in the Node Inspector.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 560.94| Modo/Blender/ZBrush/Daz/Poser
coilbook
why empty VDB boxes leave more noise even though there are no particles inside
In the image you can see half of VDB box has no particles but it leaves more noise on the plane under it compared to the parts of the plane it does not touch
BorisGoreta
Would it be possible to disable cast illumination for volumes with emission ?
haze
BorisGoreta wrote:Would it be possible to disable cast illumination for volumes with emission ?
At the moment this is not a very trivial problem, it's something we want to do, but it's unlikely we will get to it in the near future
haze
coilbook wrote:why empty VDB boxes leave more noise even though there are no particles inside
The raymarching should not leave any noise unless there is actually some pockets of very low density.
When VDBs are imported, they are automatically pruned (using openvdb itself) which removes empty space around the active voxels.
It may be a plugin issue. In that case, it may not be related to the VDB importer, since the volume would be loaded directly into octane.
BorisGoreta
Would it be possible to limit the effect of light emitted from volume to surrounding geometry by adjusting the sampling rate which we have for lights and other luminous objects ?
manalokos
We have been having problems in some renders with light leaks, it seems octane lets light into geometries through the closed edges of geometry, specially if it farther away from 0,0,0.
I've attached an example and a render showing this problem, we have some big projects that have spaces that suffer from light leaks, I've played around with ray epsilon but it doesn't solve the problem,
how could this be fixed?
The attached example shows the inside of a closed cube at 1000,0,1000 coordinate. but the problem also appears at lower distances, even at 0 can be visible.
Kind regards
Filipe
