PASS render
Goldisart
I just do not know standalone edition supports it or not
paride4331
hi Goldis,
some processes may require double renders,
though playing with render elements, active layer ID and environment Octanedaylight,
you can optimize your workflow.
attached a scene.
Regards
Paride
spot.zip
(9.54 MiB) Downloaded 267 times
Goldisart
thank you
that is 1 of the render I can not yet do all the passes I needed, right ?
OK are there any changes on this ?
namely, regarding the Render Layer Setup - double-pass
paride4331
Hi Goldis,
I would recommend you use the environment OctaneDaylight instead of 3dsMax environment.
It is much more flexible and allows you to play with reflections, backplate etc .. and also with the Daylight.
Regards
Paride
Goldisart
paride4331 hi we plan to make the duplicate render pass ... have information when write if not write I do not know whether it will be implemented
paride4331
Hi Goldisart,
I'm sorry, I'm afraid I don't understand your last question.
Regards
Paride
Goldisart
Hi. I will try to use the professional translator.
Question very prime. Whether you plan to solve double pass
rendering layer for 1 render / I took your advice and I use
the sun but me is convenient to work through a render layer setup/and such option of visualization demands two times to set a task on a render
paride4331
Hi Goldisart,
The ability to calculate different layers simultaneously, would be very comfortable, I agree.
But this should be asked to SDK developers.
Or maybe in 3ds Max, with a batch script that creates a list of differents Id with desired pass.
Regards
paride
Goldisart
if it is not in the SDK please submit it to the task list because I never work in standalone .... I opened the program only 1 time ... my knowledge is limited in this program, I don't even know how to turn the camera somewhere :)
the batch script I think will not help . because it will again be 2 times more time to render . . . must be able to work directly through the software code of the octane render
justix
paride4331 wrote:Hi Goldis,
Regards
Paride
Hi Paride ..about this.. Does the 3dsMax Environment need to be enabled? because if I don't despite I have a texture in the OCtane Daylight slot I get no light at all.. does the Octane Daylight Environment texture override the 3dsmax one?
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
Return to “Autodesk 3Ds Max”
