OctaneRender® for Maya® 3.05t3 - 9.11 [OBSOLETE]
haze
teammach wrote:we are running this plugin version and the latest standalone (tried various versions and combinations) but found an issue that forces maya to crash as soon as we enable certain bty passes such as "diffuse" for example. Even the most basic scene with just a sphere and it crashes in bot batch mode and UI mode. Funny enough, it actually renders and writes the frame and crashes at the end. But unfortunately it crashes in a way where maya batch doesnt notice
what happened and we dont get a maya exit code either way...
so that sucks if you are running stuff on a renderfarm because the render queue or even a cmd window doesnt know whats going on at the end and just sits there
need some help there asap. already submitted it with a test scene to help@
I can't find the test scene you sent, did you send it via PM?
BK
haze wrote:we are running this plugin version and the latest standalone (tried various versions and combinations) but found an issue that forces maya to crash as soon as we enable certain bty passes such as "diffuse" for example. Even the most basic scene with just a sphere and it crashes in bot batch mode and UI mode. Funny enough, it actually renders and writes the frame and crashes at the end. But unfortunately it crashes in a way where maya batch doesnt notice
Hiya :oops:
I have investigated this issue and found as bug on v3.
Also, replied to your email. We will get this resolved as soon as possible.
Kind Regards
bk3d
