Displacement offset not working! [ SOLVED ]
mickyboys
OK,
1. is someone on it?
2. Where do you get this plugin version from? I cannot find it anywhere in the forum.
3. Solved as status need to be removed
KR,
Axel
calus
mickyboys wrote:1. is someone on it?
I have no idea.
mickyboys wrote:2. Where do you get this plugin version from? I cannot find it anywhere in the forum.
viewtopic.php?f=109&t=57857
mickyboys wrote:3. Solved as status need to be removed
yes
Pascal ANDRE
BK
hi guys,
It is working in our current version as it should be. we will rename it in our next build.
Here is the reason why we changed offset as mid-level.
[ https://docs.otoy.com/#standalone-v3-us ... splacement ]
cheers
Kind Regards
bk3d
calus
BK wrote: It is working in our current version as it should be.
Hum right, this version works, only labels are wrongs.
Sorry Bikram, finally I was also part of the confusion. :oops:
So the solved status should stay :)
I tested badly, I guess the unusable cursors in the displacement node did not help . :cry:
See this never fixed old bug report about unusable cursors in the displacement nodes:
viewtopic.php?f=110&t=53179
Pascal ANDRE
BK
hey calus,
thanks for point out the labeling. i was a part of it too. :?
well, it's all good now :lol:
we will implement the displacement slider in future.
Kind Regards
bk3d
Return to “Autodesk Maya”
