Camera Focus / Z Depth passes
Brezaling
Filter set at the default - 1.2
Distributed ray tracing in the render info passes tab is checked.
Where is the Distributed Ray trace in Kernals?
Octane for Cinema 4D
2x nVidia Geforce 980Ti, 32GB RAM, Windows 10
Hi Brezaling,
sorry for the confusion but since I was not sure if you were render with passes or directly with the info passes kernel, I have talked about both. In your case only the setting in the Render passes tab is important.
Anyway I don't understand why your pass is so crisp while the beauty have DOF :roll:
Brezaling
Yeh it's driving me a bit crazy.
I did a 2x render of z-depth which will work for me for this shot but in future I want to nail z-depth in one render with clean edges.
For C4D users coming from the native multi-pass set-up to Octane's Multi-pass it's a bit of a hurdle.
A lot of the settings you need to consider are spread across multiple dialogues which can make things a bit confusing - especially if you run into a problem like this.
Sorry to bug you beppe ...
How do you normally configure your project settings to get a multi-pass Z depth (if you use lenscare / do DOF in post?)
B
Hi Brezaling,
I have to admit that it's rare that I need to have to do the DOF effect in post, please, when you can, send me via PM an example scene that I can use for testing, I will back to you asap.
Brezaling
Hi Beppe,
Thanks for your help. I'll try a new scene with fresh settings in due course and if I run into the same issues I'll drop you a line...
(I can't send my current scene as it contains models that are confidential)
B
