Rendering Alembic Curves within Modo
TheImageFaculty
BTW just tried having Live Geometry Update and Reload Mesh Each Frame... activated under Octane mesh properties and no change.
The Image Faculty ApS
https://theimagefaculty.com
OK, tried via Open / File and it brings up the same options as Import which I was using. I can indeed bring in a single frame of the alembic animation this way, as you say it gets imported as a mesh layer with the render curves option.
However I need to bring it in as an animated sequence, so when I Open/Import it and select Import All Frames in the Alembic Load Options, it comes in as a non mesh layer, as in the previous screen grab I posted.
So as far as I can tell the problem remains, there is no way to load in an animated alembic sequence and have it render via the plugin? As mentioned the behaviour in stand-alone is as expected, it brings in the alembic per-frame with no bother.
Hi Darren - you are right. I have look more at the tip2.abc file you sent me - and I cannot get it to render correctly in Octane Standalone. Do you have an OCS which renders that .abc file correctly pls?
TheImageFaculty
Hi Paul,
https://dl.dropboxusercontent.com/u/475 ... ip2_SA.ocs
Here is an .ocs with a camera in the correct position so that you can see the imported alembic. You will need to import, then plug in the previously provided tip2.abc and scrub the time-line to see the animated alembic curves (I have added a note in the node graph with details).
Hope that helps,
Darren
Hi Darren. I have spent some more time on this, and the ideal workaround would be to load the animated hair ABC file into Octane Standalone and save as ORBX and then load that ORBX into the Modo plugin as a proxy. However, there are two issues with this approach. 1) The plugin is loading the proxy host mesh over the proxy OCS/ORBX in certain situations, and this is fixed in the next plugin release (3.6.0.118), and 2) I cannot be certain, but I think there is an issue where hair segments are not be copied from the ABC file when using certain Octane API calls, and I have reported this to Otoy, who can investigate in more detail. Can you pls leave the 2 files you posted for downloading in this thread in place, so Otoy can access them.
TheImageFaculty
Hi Paul,
OK I will test this workaround and let you know if I have any questions.
I can leave the links live, no problem.
Thanks for taking a look into the issue.
Darren
Return to “Foundry Modo”
