Opening old 1.9 scenes
paride4331
Hi voltaire585,
The issue is caused by the xref.
As you know, the xref can not be edited within the main scene.
You should convert individual xref.
Then when you will open main scene it will be ok.
Regards
Paride
acc24ex
voltaire585 wrote:Ok, so it looks like the problem is that the Octane moveable proxy got switched off when opened in v3 4.18, and this was causing polycount to go to the billions. Maybe i missed that fact in the release notes. Ill let you know if I have any more problems.
- if the developer missed it, in the old plugin the switch for moveable proxy was named movable_proy now it's movable_proxy - a typo that was inside too long and the new plugin doesn't recognize, which I'm now confirming, so opening old scenes will have moveable proxy deactivated
- other than that, hell yeah, I got some materials back, great work.. will test more I guess..
paride4331
Hi acc24ex,
Did you try the latest 4.19 version?
it also works fine with the scenes 1.9
if you encounter any issue, please let me know.
Regards
Paride
viewtopic.php?f=80&t=56569
Return to “Autodesk 3Ds Max”
