Cast Shadows
- BorderLine
Seems working with diffuse material, not glossy !
This is because I don't have the backdrop object. Anyway the problem is that you have a very diffuse lighting, and the shelf with the near full glossy material can't receive the shadows from the direct lights.
Try a diffuse material in the shelf. You should see the shadows without problems ... later you can try again the glossy material, but you need to set the diffuse parameter to a value enough to see the shadows.
