Variations on a broken egg
- Rikk The Gaijin
These are fantastic, how did you model the albumen? Especially the white filament in it?
- enricocerica
- Contact:
Thanks to everyone, just made 2 prints in about 65x45cm and the result is great thank to a resolution of 5120x3200 I probably could even increase it. By the way I'll try to print one of them in about 160x110cm. As said I'm trying to prepare an exhibition, I'm very curious to see how 3D works would be considered.
Well it's a mis of various textures, I made several tests and I consider this one as enough representative.Bendbox wrote:Great job, love the series!
Is your exterior eggshell texture map custom made?
Again I made several tests and finally for the albumen I went for SSS material which was the best deal, for the filament I really didn't know where to go. I tried SSS but it wasn't good, I finally used a flat plane with a smoke image with alpha channel and surprisingly the result was acceptable.Rikk The Gaijin wrote:These are fantastic, how did you model the albumen? Especially the white filament in it?
http://www.myline.be
- Rikk The Gaijin
Wow, that's a brilliant solution! Again, excellent work buddy!enricocerica wrote:Thanks to everyone, just made 2 prints in about 65x45cm and the result is great thank to a resolution of 5120x3200 I
